South Central Region Board for the states of Texas, Oklahoma, and Louisana.
0 Days and counting!
Old Nov 20, 2005 | 09:01 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Til the
2005 FALL BRAWL!
Don't forget to bring your cameras/video/whatever!
Old Nov 21, 2005 | 03:40 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Uh oh!
My list of things to do to get ready keeps getting longer and time is getting short.
I may have to skip Thanksgiving and work on my car instead!
Old Nov 21, 2005 | 04:53 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Originally posted by esc
Uh oh!
just make 'em bring the turkey leg to you under the car
Old Nov 21, 2005 | 05:37 PM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Torque arm is ON! Just have to set pinion angle now, gonna wait for daylight. This should not have been a big job, but the car apparently had an "off-road experience" before I got it. Things did not want to line up right on the tranny cross member, so I had to deviate from the instructions a bit for the install. No complaint on the instructions nor the product, it looks first-rate. It all just took a little persuasion, and a LOT more time than I planned.
Old Nov 22, 2005 | 09:03 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Well, the weather forecast SUCKS!!! But , we all know how Hou weather can be. There's nothing we can do about it, so we continue as planned. Even if it does rain, it may be just be a passing shower.
See rain date info in link below.
https://www.thirdgen.org/techbb2/sho...hreadid=331725
Old Nov 22, 2005 | 03:41 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Anybody remember Woodstock? NO RAIN! NO RAIN! NO RAIN!...................
Old Nov 22, 2005 | 03:42 PM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
Ehat else is new?
Old Nov 24, 2005 | 10:11 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Ad much turkey as I'll probably eat, I'm gonna slow down a tenth from the extra weight.
HAPPY THANKSGIVING!
Everybody have a good safe one and we will see U at the track Fri night (if it not rained out.) By the way, the HRP officials will have to call it a rain out or not--NOT ME!
I've got good rain tires--if they will let me make a pass while it's raining (yeah right), I want to see how much slower it is than regular!!!
Old Nov 24, 2005 | 10:35 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
So if HRP calls it a rain-out. How will we find out?
Old Nov 24, 2005 | 10:51 AM
Wheel Spin's Avatar
Axle/Gears: BW 3.27
That might give me more slip than I'm looking for!
The christmas tree on their homepage indicates track status. Used to be reliable, probably not anymore. Everyone hope the weather holds!
Old Nov 24, 2005 | 10:57 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Either call the track or call me on the cell (713-823-7019). I'm going out there regardless of what the weather is doing at my house. Should be there by 6 at the very latest.
Houston Raceway Park
Track: 281.383. RACE (281-383-7223)
Fax: 281.383.3777
Old Nov 25, 2005 | 12:16 AM
Red92RS's Avatar
Car: 1992 Camaro RS
If it rains tomorrow and the track closes, I have made backup plans to go to the autorama at the george r brown convention center. If anyone plans to go to the autorama I believe it is $16 general admission.
Old Nov 25, 2005 | 08:04 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
https://www.thirdgen.org/techbb2/sho...hreadid=333103
Old Nov 25, 2005 | 11:18 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
I'm planning on trying to stuff that in my weekend as well!
Does O'Reilys auto parts have the discount tickets again this year???
Old Nov 25, 2005 | 02:46 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
We will start the elimination ladder around 8 pm.
Just look around the pit area and find where we are all pitted together.
Old Nov 25, 2005 | 03:34 PM
TexasLT1's Avatar
Car: '92 RS
well its official, I won't be there. replaced intake gaskets, still runs like ****. after I go to the gym and get some dinner I'll pull the timing cover and check the timing set. y'all have a good time.
Old Nov 25, 2005 | 03:50 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Not that I profess to know even 1/3 as much as U do about your mill, but what's it doing?
Try pulling #1 plug--tdc--see where timing mark on balancer is? and double check that both valves on #1 are closed--closed for correct amount of time in rotation?
Even that can mess with U cause timing ring on balancer can slip--it did on my L98.
What did U do to engine since last time it was running correctly?
Old Nov 25, 2005 | 04:00 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
As of 4pm/Fri--NOT A DROP OF RAIN!!!
I'm loading the car and outta here by 5pm
Call the track for latest weather info (281-383-7223)
OR call me on the cell-- 713-823-7019
Old Nov 25, 2005 | 04:14 PM
Wheel Spin's Avatar
Axle/Gears: BW 3.27
Yep, I got sunshine! Packing up. Be there by 6-6:30.
Old Nov 25, 2005 | 07:14 PM
TexasLT1's Avatar
Car: '92 RS
no timing tape on my balancer. LT1's don't have them because there is nothing mechanical you can do to change the timing besides an adjustable timing set, its all computer controlled.
Basically it just runs like total crap. Doesn't idle smoothly at all(may just be the big cam). Has no power. Wants to die at intersections, only pulls 8" of vacuum, runs excessively rich, blah blah blah. At first I thought it might be an intake gasket problem, but replacing them made no change so I'm pulling the Opti and timing cover off to check down there.
I'm hoping its something simple like the Opti isn't possitioned correctly or the timing chain is a tooth off, but we'll see in a couple of hours.
Old Nov 26, 2005 | 09:24 AM
Car: 1987 GTA
Transmission: 4L60e
well - track was fun guys. I ran a best of 14.94 @ 92 mph The weather today is looking less than great for this gathering though. I'm thinking I'd be better off going Christmas shopping
Old Nov 26, 2005 | 09:43 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Good luck--I guess I know even less about LT than I thought......U didn't miss much at HRP......really screwed up night at HRP, but we just made the best of it ......see my comments in another post.
Old Nov 26, 2005 | 11:16 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Alright its 11:15 and I am about a mile away from the park and its barely sprinkling. Its been on and off and hasnt been bad at all yet. So I am going to go ahead and go to the park at 1:00. I hope to see some of yall there.
Old Nov 27, 2005 | 09:43 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
TODAY--SUNDAY--1PM--BEAR CREEK PARK!!!
RedLeader289
May 28, 2019 01:47 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
