South Central Classifieds for the South Central Region
Thirdgen Swap Meet!!--look inside!----->
Old May 7, 2006 | 05:17 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
A recent post/thread gave me an idea. Let's give it a try for a while, and see how it goes. If U have Thirdgen parts or thirdgen performance parts to get rid of locally, list them here in this thread. Even though there is a classified forum on the TGO board, let's give this a try.
Thread guidelines:
1. Make one post--AND ONE POST ONLY-- listing whatever U have to get rid of--Thirdgen parts only!
2. Keep your post/list of parts to get rid of, current and up to date. When U need to add or remove something to your list, use the edit feature.
3. Please take it to "PM's or emails" when U start talking about money --please limit the questions in this thread to-- "is it still available" or "what does it fit or type/style etc"-- type questions.
4. Any other "thread guidelines" will be posted if and when the need arises! If this idea/thread does not work out or little or no activity or is misused--the entire thread will be deleted!!!
5. Universal fit parts and /or items such as tools are OK to list!
6. Complete cars for sale may be listed here.
7. Parts wanted/needed may be listed here also.
8. I will be "pruning" the dead posts out of the thread when appropiate!
9. How about posting items wanted. Someone might having it sitting in the corner of the garage or might have seen it at the bone yard.
So if U got Thirdgen parts or Thirdgen performance parts to get rid of-- START POSTING!!!
Old May 7, 2006 | 05:54 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
1. Auto Meter 3 1/2" Sport Comp tach #3780-- 0 to 8000 rpm--270 degree sweep includes mounting bracket--only 4 wires to hook up-- works perfect
2. SOLD! OEM console shifter for 700R4-- includes all brackets and cable
3. Aftermarket water temp gauge--brand??? (I think it's an Elcheapareno--but it works fine!) -- 130* to 280* /90degree sweep --includes mounting bracket
4. OEM air pump --off of my 89 IROC 350 TPI
5. TCI 700R4 deep/extra capacity aluminum finned tranny pan
6. OEM 700R4 tranny pan
7. 4 regular hi/lo beam headlights--3 prong
8. 2 regular HI beam headlights --2 prong
9. 1 set Fel Pro #1406 D shaped exhaust gaskets--unopened
10. 1 OEM steering wheel of of 89 IROC
11. 1 OEM rebuilt Delco OEM starter --fits 350
12. OEM standard 3 piece rear spoiler--white --off my 89 IROC
Old May 9, 2006 | 04:18 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
I have 2 slp 17" zr1 wheels for sale. immacullate asking 200 $ obo. 2815941354-jay
Old May 9, 2006 | 09:37 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
bowtienick's stuff
-th700 trans, has tailhousing and input seal leak,shift kit,working condition
-set of accell 30#/hr injectors $100.00
-extra 7730 ecm $20.00
-extra t-tops (rs style) $50.00?
-accell 300+ cd ignition with harness for 87-92 remote cap dist. $100.00
-used edelbrock performer intake $10.00?
a few more things
-lt1 conversion intake, needs bolt pattern drilled $75.00
-zz4 head, only one, never installed $200.00
-used posi 2 series carrier $50.00
interested people can reach me at 281-970-6558, im usually home from work around 4:00pm or email me
Old May 10, 2006 | 01:40 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
my stuff
Ive got quite a bit of junk too. This is the big stuff from my 91 formula
Stock Torque arm
passenger side door sill grey
drivers side roof post cover, black
stock floor mats, OK condition, brown (90 firebird)
back seats, bottoms only, grey
Catco dual cat setup, stainless
Old May 11, 2006 | 10:41 PM
Red92RS's Avatar
Car: 1992 Camaro RS
Borg Warner nine bolt( 2.77 gears I believe) posi no brakes included- $100 obo
p.m me if interested please
Old May 12, 2006 | 12:34 PM
aldixie's Avatar
Car: 1991 RS Camaro Convertible
1.Flowmaster rear muffler with over axle exhaust pipe. $50
2. Kick panel speaker panels with speakers, black but need recovering $20
3. Glass T-tops and case. $40
4. Set of Eagle alloy wheels 16" two are bent and will need some straightening (fixarim in Houston can fix) $100 the four.
Can email pictures of any of the above just PM email address.
All parts pickup Deer Park just off of Beltway 8 and 225
Phone 281 382 0025 or email aldixie_2000@yahoo.com
Alex
Old May 14, 2006 | 08:54 AM
Barry 85IROC's Avatar
Car: 1985 IROC
Engine: 355 4-bolt
Transmission: Specially-Built Exner TH350
I'm still in the process of converting to auto, but I have an
1.An almost perfect dual-snorkel air-cleaner set-up,$150
2. everything from the manual trans (hydraulics) and pedal assy. $100.00
3.stock fuel line cooler,$25
5.K&N 7" air cleaner, 5$
4.3 sets of grey door jamb covers, $30.set
5. brand new Edelbrock Performer Vortec manifold (used 1 mo.)$100SOLD
6. Proform T-5 shifter$75
7. Front springs (for a Big Block)$30.00
8.One pair turn signal lenses(not cracked....need polished)$20
9. NEW leather T-5 shifter ball $40
10. Fried T-5 (contact me. I will get it repaired under warranty)
11. IROC hood $100
12. One brass and copper radiator. Direct fit for a Thirdgen $50.00
14. Cloyes quiet drive gear set NEW $100 SOLD
13. Holley 770 Street Avenger $150SOLD
Old May 20, 2006 | 08:44 PM
systemofalldown's Avatar
Car: 1982 Camaro Z28
Engine: 454
Transmission: TH400
*rims
*dash pad & dash
*hood and hood struts
*seats
*center console
*instrument cluster SOLD
*Grant steering wheel
*doors complete with power locks and power windows
*tail lights
*two transmissions
*rearend
*armrests
*radiator
*a/c parts (including accumulator, evaporatore core, condenser, compressor, lines..)
*coolant overflow tank
*windshield washer fluid tank
Old Jun 2, 2006 | 11:57 PM
Slave One's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
Drivers Side Fender...
Hey there guys!
First of all, this swap meet thread is genious!
Gentleman, I am in desperate need of a drivers side fender, anyone got one I could pickup??
Also, I am looking for a flowmaster...
Oh yea, and a plastic hardtop headliner...
Thanks Guys!
Old Jun 17, 2006 | 03:37 AM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
I got lots of 82-84 Firebird parts in the Oklahoma City area
405-410-4220 Call before 3pm on Weekdays
Old Jul 12, 2006 | 01:42 PM
UDLooz's Avatar
From 89 IROC red with black and silver stripes along bottom.
Both front fenders, some dents/dings.
IROC hood, no louvers, very minor surface rust where paint peeled.
Running L03 305 long block (block, heads, intake), TBI unit and accessories not included. (considering pulling for 350 swap)
Red interior parts - seats (driver has some large tears, pass. has some small tears, rears are ok) power vinyl door panels, sail panels, plastic pieces
Gray seats from 91 RS - very small rip on side of driver seat, otherwise excellent.
Stock air cleaner.
Rear window louvers.
Would consider trading the entire car for a decent V8 RS if I could keep the IROC wheels and put the RS wheels on it.
Old Jul 22, 2006 | 07:29 PM
invaderzim1915's Avatar
Car: 1989 rs camaro
Engine: 305 TBI
Transmission: auto
Camaro side skirts i need camaro side skirts just the part that mounts on the car its self right below the door. http://i55.photobucket.com/albums/g1...1/untitled.jpg
the top part with the emblem is what I need
any one in houston with a good LO3 or 350 for around 400 to 500
Old Jul 22, 2006 | 10:26 PM
moninjars's Avatar
Car: 92 Rs
Engine: lo3
looking for a front bumper, ground fx, and a right hand fender in the san antonio area. some freaking illegal immigrant with no insurance just hit my car with his POS. any help would be nice
Old Jul 29, 2006 | 01:42 PM
rudyt5000's Avatar
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
i got a couple of wheels for sale and misc stuff
1. 17x9 1/2 in. 4th gen Zr1's all 4 without tires $300
2. 2 Weld prostars 15x8 w/good tires $150 SOLD
3. Set of a/c vents for third gen $5
4. 4th gen front power seats excellent condition grey/black wired for 3rd gen and 3rdgen back seats decent shape. $50 SOLD
5. Front bumper for third gen. $30
832-398-2662 Rudy if no answer leave message or pm me on this site
Located in SE clearlake
Old Jul 30, 2006 | 08:52 AM
Stephen's Avatar
Car: 87 GTA
WANTED:
black sunvisors
FOR SALE:
Parts are from various years...'84, '86, '90, or '92. The year models I owned. If not listed, not sure which part is from what year. Look at the pics, and see if they match yours, or research...
Camaro Dash Gauge face, lens, and cover, 86 IROC-$25
Door Panel Handle trim pieces with power window button holes-$10/each
The others are interior trim pieces, I think for front seat mount covers.
Been too long since I took them off to recall exactly. If you need them, you'll recognize them.-$5/set
The first pic is of everything, but the red outlines represent the individual groups listed for sale. 6 total.
Email for more info.
Old Aug 2, 2006 | 08:59 PM
79xthta's Avatar
WTB Posi Disc Brake Rear End and the metal piece on the back hatch or the whole hatch if the price is right.
Old Aug 13, 2006 | 06:57 AM
vortecbird's Avatar
Car: 91 Firebird
Engine: 350 Vortec TBI
Axle/Gears: 2.73 single tire fire
Trailer hitch with chrome removable drawbar, flat, not square. Includes wiring adapter. $100 o.b.o
3" custom exhaust. Magnaflow cat, flowmaster 80 series muffler. Chrome tips, straight with rolled lip. Was all welded, had to be cut for removal, so will have to be welded back on. $300 o.b.o.
SLP Y-pipe for single cat. Has hole that needs welding up, make offer.
I don't want to ship due to weight and size (exhaust is in only two pieces).
Located in Orange, Tx.
im looking for a 3rd brake light to fit my 91 firebird. the one that is on the inside of the hatch. i need at least the internal parts that hold the bulb, but would gladly take the whole assembly.
Old Aug 16, 2006 | 10:12 AM
bigmaciroc's Avatar
spoiler, rims and hood
iv got a rear spoiler i dont know what model camaro it came off of but it fits on camaros. it has a small chip on the right corner. $20 pick up only
and i have gold iroc wheels, bad tires, but only asking $100.
buy the wheels, get the spoiler for free. pm me if your interested
stock hood, flat black, $100 OR TRADE for iroc with louvers, or z28 with blisters. buy hood, get spoiler free.
pm me for pictures
Old Sep 8, 2006 | 09:31 PM
bigbird89's Avatar
Car: 86 Firebird
Love the swapmeet! I need a rebuildable 350 pretty cheap. I've got a complete 89 firebird auto with a 305 tbi that I need to get rid of or I will part it out.
Sorry - kinda new on the board - I'm interested in the 350 engine for $250 - can you e-mail me at mchristopher@charter.net to save some space on the board? Thanks!
Old Sep 10, 2006 | 06:23 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Here's what I have for sale........
Tach - Autometer monster 5 in. with shift light.........................$75.00
1991-1992 Ground effects (lower rocker and rear quarter extensions) great shape - $100.00
BRAND NEW .030 350 pistons /rings (speed pro/sealed power) hypereutectic, pressed fit set of 8 with all rings / pins ect.... new in the box...... make offer
All parts listed are in working order.
I can meet and or deliver in or arround the Houston area or can meet at a mutually convenient location for pickup. Cash only.
PM me here on TGO or you can e-mail me at: ms1badZ@yahoo.com
Thanks!
Mike
Old Sep 11, 2006 | 09:14 AM
arl_89formula's Avatar
Engine: 355 Staelth Ram
Axle/Gears: 3.70
here is what i have;
ANY INTERESTS? Stealt ram 30lb injerctors
I have the lower intake for a stealth ram powder coated red with tons on cnc porting working on the runners, fuel rails with adjustable fuel pressure regulator, Fuel pressure guage, and 30lb fms injectors, the fittings and 6an fuel lines that adapt the stealth ram to the stock fuel lines. All has around 500 miles on them. I don't have the top plenum becuase someone broke into the shop were the car was kept and stole a bunch of stuff and that was part of what they took. Anyways i'm taking interests and offers for it. Let me know.
https://www.thirdgen.org/forums/at...tealthram1.jpg
Hope this link works and helps. Let me know any offers. Thanks
Edelbrock hydraulic roller cam ( dur@.050 234/238 lift (1.6rr) .575/.585 lobe seperation 112* Intake centerline 107*) - 175 obo
CompCams Pro Magnum 1.6 roller rockers - $200 obo
CompCams Pro Magnum Roller Lifters - $ 180 obo
Edelbrock Victor Jr heads 64cc 2.08 and 1.60 valves Custom Dual Springs and Perfesionally CNC ported all the way through and ARP studs
Old Sep 19, 2006 | 02:08 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Edited...
Old Sep 19, 2006 | 04:37 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
I have a 4l60e trans from a '03 GMC 4.3Vortec pickup.
Condition: ~30k miles, operating properly when removed.
Removed because of small crack at cooler line connection,
and was warrantied for replacement. I'm told a good welder
could fix the problem easily, without disassembly. Am looking
for $300, but also need to get it out of the storage shed.
Would prefer pick-up (League City). But it's in the original
GM shipping crate, if someone want's to pay the freight.
PM if interested.
kk
Old Sep 19, 2006 | 09:02 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Camaro taillight lenses, no scratches- 20 bux (and I'll even polish them for you)
Torque arm, painted black- free
LCA's- free
set of heads for a 2.8, 3.1 or 3.4L V6- 10 bux (one head has been massaged, will do the other one for an additional 30 bux)
Upper intake manifold and throttle body for a 3.4L V6-free (solid aluminum, and weighs like 15 lbs...hence why it's 5 bux)
2.8, 3.1, or 3.4L Billet aluminum fuel rail- 5 bux
TPI intake runner gaskets from BBK- cost you one bottle of Shiner
Misc. Gaskets and seals for V6 thirdgen motors (no headgaskets)- free
Front /rear rotors for thirdgen F-body- free
NONE of the free stuff ahs been claimed yet...
Oh yeha, almost forgot:
RUNNING 2.8L longblock. Had perfect compression when I yanked it out, and about 110K on teh clock, doesn't burn oil. Could prolly use new valveseals (10 bux). Motor does NOT have brackets or intake manifold- 100bux CASH
Old Sep 24, 2006 | 04:53 PM
User Name:'s Avatar
I need Driver side (1992) bottom Trim piece...Passenger black arm rest...Passanger side fin...in the Oklahoma area, plz. Thx I dont know if this is the right place for this, but yeah.
Here pretty soon I got my 305 carb engine for sale/trade.
Old Sep 28, 2006 | 10:26 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
iim in the baton rouge area.. i need some rims 17 or larger. for the big brake up grade.. thanks
i also have a rpm air gap intake thats been ported for sale if any one needs it
and a 4th gen console no lid on shift boot.. thanks
Old Oct 1, 2006 | 12:31 AM
estone06's Avatar
Car: 1991 Camaro RS
Engine: 350 stroker .40 over 11:1 comp
I AM LOOKING FOR A COWL HOOD FOR A 91 CAMARO!!!
Old Oct 2, 2006 | 05:43 AM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
Wanted: TPI Plenum and Base that will fit my car. I think '90-92 will work.
Old Oct 14, 2006 | 02:19 AM
84Maroonta's Avatar
Car: 84 Trans AM, 89 Camaro
I have 2 of the disc brake rear ends. Make offer. Im not looking for much...... seriously
they are both complete, I know one is from a 85 z28 and the other looks just like it but im not sure on the year. $100. takes both
san antonio texas
yeah two complete rear ends
ok got these two complete rear ends (disc brakes) 75 takes both. I need them gone. I need gas.
I beleive they are 2.73's. they will need some good cleaning. Rotors will need
to be turned.... ect. They have been sitting for a while now. you cant go wrong for this price.
10 bolt
SOLD
Old Nov 14, 2006 | 11:04 AM
bigmaciroc's Avatar
I need 2 16" Iroc wheels. HELP!!!!!!!!!
Old Nov 30, 2006 | 10:23 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
I have gone thru and cleaned up the thread, like I said would when we strted this. I have merged everybodies posts so everybody has one post only!
PLEASE, PLEASE, PLEASE, go thru your post and update it! If U no longer have something U want to get rid of or no longer are looking for something, please update your post!
PLEASE use PM's or email's whenever possible! Ideally this thread should contain listings only so the thread is not cluttered up with unwanted posts.
Thanks for making this idea/concept a sucess!
If U want to delete your post completely, let me know and I will do it for U!
Old Dec 16, 2006 | 06:17 PM
aldixie's Avatar
Wanted. Standard Camaro Exhaust manifolds
Hi Guy's,
Looking for a pair of standard camaro exhaust manifolds. Anyone done a header upgrade recently!!!! Prefer a cheap pair, its for a project I'm working on.
Someone must have a pair kicking around somewhere. Houston area.
Phone 281 382 0025 or 281 478 6199. Leave a message if no answer.
Thanks,
Alex
Old Dec 16, 2006 | 10:38 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I've got some LT1 cast iron manifolds up here in Dallas (Plano, actually) if you don't find any down that way......
Old Dec 31, 2006 | 10:35 AM
Ported Tpi complete intake with throttle body for sale, made 453 hp on a 383
8325939140
Old Jan 9, 2007 | 11:09 AM
drexton311's Avatar
Car: 1989 T/A
For Sale!!
I have:
Set of glass t-tops for third gen T/A and Camaro. (drivers side has cosmetic trim damage...both seal up nice and tight)
Set of grey cloth Trans am seats out of a 1989 T/A. In good shape...moderate wear on drivers side though.
Set of Ebony rear seat belts (no buckles) out of 1994 Trans AM
hood from 1986 Mustang GT. (Has holes drilled for hood pins)
LX Style spoiler w/3rd brake light for fox body Mustang.
Tired of looking at this stuff/best offer takes them. I'm near Tulsa, Ok.
ALSO-- I need a good 350 for rebuild. Call or email if interested:
918-809-2933 drexton311@yahoo.com
Old Jan 17, 2007 | 12:04 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I will soon have a few things for sale myself once I get my engine out of the car here in the next couple of weeks.The shifter and trans cooler can go now but I dont have the trans out of the car yet. Let me know if interested:
Edit-Everything is now out of the car and ready to be moved-
700r4 trans. Was working when the car last ran about 6 months ago. But it shifts kind of sloppy sometimes and wont shift into OD. The guy I purchased it from said it was rebuilt shortly before I bought it and the internals seem to be in good condition, but I dont know what the actual mileage is. I have been told that it could just be the servo, but I am not sure. I really dont think it needs rebuilt.Come pick it up at my house for $60 *SOLD*
Aftermarket trans cooler I purchased New from Orieleys in the summer of 05 for $55. It has very little mileage on it and is in good condition. $20
B&M megashifter --SOLD--
Stock flex plate for pre 85 cars w/ 700r4 tranny. I had it bolted to my 1978 motor and it worked with the 89 starter that came on the car, in great condition. $20
Stock Oil pan from my 78 010 casting motor. Work just fine with my car, but I went with a new chrome one because it came with a one piece gasket. $20
PM me if interested.
Last edited by IROCaholic; Sep 6, 2007 at 10:35 PM. Reason: Edit changed pricing, added items
Old Feb 18, 2007 | 08:13 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
ATTENTION EVERYBODY:
PLEASE TRY AND USE PM'S OR EMAIL'S SO THE POSTS IN THIS THREAD ARE MAINLY JUST THE LISTINGS OF ITEMS AVAILABLE OR WANTED.
ALSO, PLEASE TRY AND KEEP YOUR LISTINGS UPDATED, AS FAR AS WHETHER SOMETHING IS STILL AVAILABLE!
I will be going thru and cleaning up this thread, as I said I would when we started doing this.
Thanks again for everybodies cooperation in making this thread/concept a success!
Old Feb 20, 2007 | 12:55 PM
LilHot's Avatar
Car: 1991 Z28, 1991 GTA
Engine: 5.7 TPI, Headers, 3" Exhaust, BBK
Parts for Sale
Parts that I have for sale:
A set of 86 Iroc wheels w/ tires for sale.... asking $250. Tires still have about 50%-60% life on them.SOLD
86 Iroc hood NO inserts, decent shape need paint $50 obo.
A set of long tube Hedman headers $85.
I live in Rosenberg but work in Houston (Springbranch Area). PM me if you need pictures or if you have questions.
Alberto
Old Feb 21, 2007 | 01:48 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
COMP CAM XE 236-242 duration @ .050, 520 540 lift, 110 LSA
Retainer, guids and rollers, cam retention plate
Cloys true double roller timing chain
Comp Cams hardened pushrods.
All this was operating together on my 357 for 3500 miles,
the head cracked abd locked one cylinder and bent a rod,
This cam is awsome, radical lope but streetable, did not beat me to death
ALL ABOVE FOR ORRIGINALLY EQUIPED ROLLER MOTOR 87+ ONLY.
All above asking 300$
Cammel humps-1.94, 1.60, stock castings, fresh rebuild with seals and valve job ready to bolt on, no factory accesory holes.
As is 250$ obo
W/ stage 1 port-300$
W/ stage 2 port 350$
W/ stage 3 full port and polish 400$
Factory LT1 Corvette heads need freshen up or rebuild 95 model heads
As is 200$
Stage 1-250$
Stage 2-300$
Stage 3 full port and polish-350$
95 Corvette LT1 Roller cam 50$ OBO
Old Feb 25, 2007 | 05:04 PM
DMcRacer's Avatar
Car: 35th Ann. SS
Transmission: 4l60E
Axle/Gears: 3:42
92 Z28 TPI/Auto $2800 obo
********Car is sold*********
1992 Z28, 305tpi/auto,124k miles,ZR1 17" wheels,4th gen rearend with disc brakes, shocks & struts have been replaced, lowering springs added, aftermarket rear lower control arms & BMR relocation brackets. 4th gen seats. New intake gaskets, blower motor and cat. converter.
It needs paint. Could use rear tires, replaced fronts last November. Steering gear box is sloppy.
Car is driven daily, does not smoke or use oil. Very reliable. Tagged till 10/07 inspected till 2/08.
$2800 obo, might consider trades
Old Feb 25, 2007 | 08:35 PM
  #42
GRASSHOPPER's Avatar
Car: 1983 Z28
Engine: LG4
Transmission: automatic
Want to buy lower gfx (rocker) for 1983 z-28 drivers side
Old Feb 25, 2007 | 09:50 PM
  #43
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
10 bolt drum brake rear end from 92 Z28 for sale. Posi with 2.73 gears. Drums turned and brand new shoes included.
CD Radio player from 92 Z28. Works fine as far as i know, its the one with the yellow writing - SOLD
Front fog lights from 92 Z28. Need new glass surrounds but reflectors look fine.
700r4 trans and TC - electric speedo geared for 2.73 gears as above - SOLD
Disc/Drum prop valve & Master cylinder.
Stock steel driveshaft, needs rear U joint.
Complete dash from 92 Z28 including automatic center console. Dash pad needs to be replaced due to tears on the corners.
Door cards (panels or whatever yous all call them), perfect shape.
Can ship smaller stuff, the big stuff is pickup only, NE Oklahoma.
Cheers,
Richard.
Old Mar 2, 2007 | 09:11 AM
  #44
Car: '91 Formula
Nitto Drag Radials Cheap in Houston
These are Nitto Extreme Drag radials. They have less than 1000 miles and about 6 strip passes on them. They are large, 275 60 R15. Get a set of lightweight 15" rims and hook good at the track.
I went to slightly smaller tires. As I recall these are about 26.7" diameter.
$150 each new, come by and pick them up for $100 for both. I need them out of my garage
Old Mar 3, 2007 | 08:14 AM
  #45
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I need the small AC vents that go on the ends of the dash on the bottom of a Camaro. Anyone have any?
Old Mar 10, 2007 | 12:30 AM
  #46
84Maroonta's Avatar
Holley Carbs
I have two 650 vaccum sec. carbs. I just pulled one of my running car 2 weeks ago. I need both gone fast $75 takes both. Flowmaster muffler...... make offer. Has chrome tips on it now.
Old Mar 12, 2007 | 10:44 PM
  #47
Ricco's Avatar
Engine: 350 HSR
Axle/Gears: 3.43
Originally Posted by 84Maroonta
I have two 650 vaccum sec. carbs. I just pulled one of my running car 2 weeks ago. I need both gone fast $75 takes both. I also Have a stock t-5 shifter $20. I t-5 tranny that needs to be rebuilt $50. Flowmaster muffler...... make offer. Has chrome tips on it now.
Where are you at? Why does the T-5 need to be rebuilt, what is wrong with it?
Old Mar 13, 2007 | 07:16 PM
  #48
aldixie's Avatar
Interested in the T5 as well. What year is it? I think your in San Antonio is that right? Is it with the bellhousing or just the bare transmission?
Thanks,
Alex
Hi Eric,
I have those. I'm about to part out the 85 Iroc I just picked up.
Alex
Old Mar 13, 2007 | 07:21 PM
  #49
aldixie's Avatar
Parting out 1985 Iroc Z28 305 TPI/700R4
ALL PARTS SOLD....
Attached Thumbnails Thirdgen Swap Meet!!--look inside!----->-dscf0020.jpg   Thirdgen Swap Meet!!--look inside!----->-dscf0021.jpg   Thirdgen Swap Meet!!--look inside!----->-dscf0022.jpg
Old Mar 16, 2007 | 12:42 AM
  #50
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Looking for a L98 long block complete.
Running or not, just must be rebuildable and a fair price.
Must be one piece rear main and set up for hyd roller from the factory.
Alternatively, if u have a short block or heads for one or short block from anything else one piece rear main + roller, let me know.
I am in Houston for school
later
Jeremy
