Need help with rear Katy/Houston area
I've been having a few small issues with my car lately that have been keeping me from enjoying it. First my rear trunk motor stopped working, but I should have that resolved soon. The bigger issue is what seems to be a pinion seal leak. It is a pretty slow drip but it seems to be spraying under driving conditions. I got a pretty good look at it when I put the TA cover on there this weekend, and it looks like the yoke seal is separated from the pinion seal by about 1/8". Is that unusual? I can see the seal and it looks ok, but oil is still leaking. I've been told that if you want to replace the seal with the carrier in you have to be careful about the install. I don't have all that much experience with the rear suspension and could use some help with finding out the best way to go about fixing this. I definitely don't have the expertise to mess with removing the carrier and reinstalling it. I'd appreciate any help I could get with this, thanks.
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
if U want it done right--go talk to Owen at ARD
Owen
ARD--Advanced Racing Dynamics
5023 Addicks Satsuma rd, Suite b,
Houston, Texas, 77084
832-593-9140
From I-10 and highway 6, go north past Keith Harrow till you reach Addicks Satsuma. Take a right turn and go about 100 yards down, and you will see the sign and it is located on the left in a business park.
Owen
832-593-9140
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
give ARD a call, I can swap that seal out no problem. Rear end assembly is my specialty
Well I was gonna give you guys a call....but then my priorities changed. My engine caught fire just now, but I caught it quickly. Apparently it started at the distributor and melted through the brake booster line and a few other vacuum lines running out of the manifold. When my brakes went I figured it came unhooked. I pulled over, popped the hood, and instead there was a fire on my distributor. I was somehow able to blow it out, and thank god. The fuel rail on that side was right next to the fire. I'll say this about MSD super conductor wires, they are TOUGH. They were right in the fire and didn't even come close to melting one bit. Damn, I have BAD BAD luck.
Car: 1992 Camaro RS
He is not joking either, i saw him change gears in a 4thgen in 20 minutes by himself while 3 other people just stood behind and didn't lift a hand to help
That sux, I hope u can get it fixed soon
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Feb 2, 2016 11:43 PM
LT1Formula
Nov 16, 2015 01:13 PM
Dialed_In
Aug 20, 2015 01:45 PM
