Question????
From: Houston is where my address is Baghdad is where I work
Car: !988 Iroc-z
Engine: 355 L98 Few nice Mods
Transmission: 700R4 with 2400 stall
Axle/Gears: 373
Question????
Do you think these things here will produce 12's out of a stock bottom end and a decent cam?
SB-Chevy Cast Iron Vortec Cylinder Head
206cc Intake Ports
65cc Combustion Chambers
2.000'' Int/1.550'' Exh Valves
.530'' Max Lift
Assembled Sold Individually
Blaster 2 Coil
Coil Bracket
MSD 6 AL Ignition Box
Superconductor 8.5 Universal Spark Plug Wires
Universal 18'' Superconductor Coil Wire
XHD 10'' Street/Strip Torque Converter
29-3200 Stall Speed
Pro Magnum Roller Rocker Arms
For Chevy 265-400
3/8'' rocker stud
1.6 ratio
16 per package
TPI Nitrous System
Camaro/Firebird and Corvette
100-150 horsepower
__________________
206cc Intake Ports
.530'' Max Lift
Blaster 2 Coil
Coil Bracket
29-3200 Stall Speed
For Chevy 265-400
3/8'' rocker stud
1.6 ratio
16 per package
TPI Nitrous System
100-150 horsepower
__________________
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Yeah, those heads should easily flow enough to give to give you a 12 second pass. But it depends on your combo. Is this thing going to be a TPI setup? Because if so you have to be careful with your cam choice, youll need to upgrade your base and pleneum etc. to get the most out of those heads. You will also need to have a chip tuned for it.
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
without the nitrous--no to maybe-- with the nitrous yes
Talk to Larry Dunlap he has run 12.78 stock bottom end--I have run 13.20's stock bottom!
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Sound possible to me, enough nitrous (as the ricers callit Nawzz) you can prolly go 11s im sure.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
At the risk of a stock lower end that is, i sprayed a 200hp hit on a stcok TBI 305 for 1 year before the fuel pump crapped out and detonated a cylender.
Car: !988 Iroc-z
Axle/Gears: 373
Now with these heads should i get the shorter runners or should the stock ones work fine?
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, it ran like a scalded ape, it surprised allot of LS1s and olmost got into a couple of fights because people did not wanna believe it was a 5 litre, but anyone that recently met me know my size may have been a deterrant
Never got it to the track, i was too poor to have slicks back then.
Never got it to the track, i was too poor to have slicks back then. Senior Member
that just goes to prove that gas jetted and tuned correctly will run for a long time
Car: Faster
Engine: Than
Transmission: You!
Nitrous with cast pistons .................. yikes!
I've seen some catastrophic failures and some that last awhile. It's a crap shoot.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
You ever see the super chevy(i think it was) or CHP mag that they went for bust on a 90% stock 76 350, only had a n20 cam, and intake n carb, safely went 325 shot, i think they went 425 shot or somthing like that when it popped a piston finally, it was so much that there was a dense fog of fuel and nitrous above the horn of the carb on the dyno, chevy power!!! Like a rock...a cast iron piece of rock.
