South Central Region Board for the states of Texas, Oklahoma, and Louisana.
please advice quick.
Old Jun 10, 2007 | 07:51 PM
RESENDEZMARIO's Avatar
Car: 08 cobalt ss turbo, workin on iroc
Engine: 355
could u use the stock iroc transmission with a 355?
Old Jun 10, 2007 | 08:34 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Re: please advice quick.
need more information!!!
are U asking about manual or automatic? and the answer is both to both!
Old Jun 10, 2007 | 08:39 PM
Engine: 355
700r4 automatic. would i be able to use a 355 with the 700r4.
Old Jun 10, 2007 | 11:11 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
it depends on how strong the motor you build is as to how long the trans lasts.
you could build a killer 283 & smoke a stock trans on the first pass.
a mild 355 shouldn't be any problem for a stock 700.
how much power are you talking about, over 350HP?
you can build a 700 to handle more power, how much more power depends on how much you want to spend. a well built 700 with the right converter can take 600 HP & 600 pounds of torque.
of course a used stock trans won't handle as much power as a brand new stock trans will, parts get weak & wear out from use.
you can talk to Owen at ARD if you need something stronger than stock, he knows his stuff.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
