South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Buying an LT1
Old Jun 8, 2007 | 02:16 AM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I'm getting ready to purchase a '95 Formula with 144,000 miles on it!!!
Is there anything specific that I need to look for or check out before buyinig car? I have never really read up on 4th gens or read much about the LT1.
So any insight will help! THANKS
Sorry for the misunderstanding here, I am purchasing this vehicle to replace the drive train in my '89 Formula with the LT1 and 6 speed.
I just wanted to make sure there was nothing specific that fails with these LT1's???
Old Jun 9, 2007 | 11:18 PM
RITTER's Avatar
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: Buying an LT1
Is it normal for LT1's to run low oil pressure by the stock guage reading? I have heard that they just run low, but that scares me!
Old Jun 10, 2007 | 01:25 AM
TexasLT1's Avatar
Car: '92 RS
Re: Buying an LT1
at idle I only show about 10# oil pressure on the stock guage.
Old Jun 11, 2007 | 12:40 AM
RITTER's Avatar
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: Buying an LT1
So its not a big deal if the needle is right below the first line on the oil pressure guage?
Old Jun 11, 2007 | 08:58 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Re: Buying an LT1
at idle or at driving speed.
sometimes the thirdgen and fourthgen dash gauges are famous for puttin out low readings. My wife's car has always idled in the red, but comes up at speed--not to say it is something U should not check out.
Old Jun 11, 2007 | 09:19 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Buying an LT1
my Lt1 runs the same type of oil psi,cold 60psi,operating temp just above the red-20psi normal driving shows 30-35psi.
since you will have the drivetrain out it would not hurt to instal a new oil pump 30.00 is cheap
Old Jun 12, 2007 | 01:05 AM
systemofalldown's Avatar
Car: 1982 Camaro Z28
Engine: 454
Transmission: TH400
Re: Buying an LT1
The opti spark on those things are a joke. That's the one thing that bothers me about LT1s. You have to remove practically everything in front of the motor to get to it. Radiator, fans, etc.
Old Jun 12, 2007 | 07:24 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
Re: Buying an LT1
After a 100k Lt1's have a thing about cam bearings. I have had two cam jobs turn into motor jobs due to the cam driven nature of these motors putting stress on the the cam bearings escpecialy the front one. This is also why when a lt1 gets a lot of miles on it the pressure is crap. I remember a impala ss that had over 200k and the guy wanted lt4 heads and cam. I went to pull the cam and i was like what the hell is sticking? I ended up using a prybar and a hammer to get it out with 3 of the cam bearings attached
BumpaD82
Feb 26, 2016 02:57 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
L0tuS
Oct 4, 2015 08:07 AM
New2Chevy
Sep 28, 2015 12:35 AM
L0tuS
Sep 4, 2015 11:16 PM
