South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Fuel pressure and flow numbers for 1990
Old May 26, 2009 | 10:49 AM
kucharskimb's Avatar
Couldn't find what I needed. Does anyone have the fuel pressure and flow from the stock, in-tank pump for a 1990 FB with 305 TBI Auto?
Matt
Old May 26, 2009 | 11:41 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Re: Fuel pressure and flow numbers for 1990
A 195 lph pump will work. The TB will regulate it down to what it needs. Then you have enough pump already installed if you want to go TPI later down the road....
Old May 27, 2009 | 04:51 PM
thanks. but we're going to carb and need to reduce pressure.
Old May 27, 2009 | 06:46 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I don't know anything specific...but....
Most TBI units run around 15-25 psi.
I suggest that you use a bypass regulator and adjust it down to 5 or 6 psi.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
