Carbed+v8+MSD6AL - tach reads exactly 2x
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
I have read and looked for a 'tach filter' in my factory tach wiring and found none. I have spliced a wire from the MSD6AL tach outlet to the factory tach wire that went to the factory distributor. The tach was working fine with the Accel distributor before i installed the MSD6AL. With the MSD the tach reads exactly double the actual rpm.
Has anyone run into this problem and can share a solution?
EDIT: it appears i need a tach adapter.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
