i need help on a transmission problem
Car: 1982 camaro z28
Transmission: 350 turbo
i have a turbo 350 in my camaro and it pushing tranny fluid back up throught the dipstick tube what could be the problem cause i need to get it fixed cause it putting tranny fluid on my headers and its becoming a real problem and it only does it when you drive it
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Re: i need help on a transmission problem
When was the last time you changed your fluid?
Old fluid can foam up.
Car: 1992 Camaro Z-28
Engine: 355
Transmission: Custom 700-R4
Axle/Gears: Stock 4th gen
The vent tube is most likely your problem. It is probably clogged with gunk. No big deal, happens with those older transmissions.
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
