New Owner
Car: IROC Z28
New Owner
Greetings and Salutations.......
i just bought an 1989 IROC Z28. i am a happy owner. i live in killeen. i've been looking for an iroc for about 6 months and i found the right one. i have a problem with it. it cranks right up and runs really good. when i turn it off, it doesn't crank up. i have to wait about 15-20mins before it cranks up. has anyone ever ran into this problem? i've changed the maf and tps sensor.
thnx in advance for your help
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Re: New Owner
If your car has a chip in the key, then I would look at threads about fixing or even Bypassing VATS completely before throwing parts at it that aren't even in the starting system.
The next thing I would look at is the starter, but look at VATS first.
