South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Inspection park brake issue
Old Mar 16, 2021 | 10:07 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
When I was moved from CA to TX 5 plus years ago I tried to register the Firebird which required an inspection. It failed because the tech applied the park brake and with the car in gear gave it some gas. The car moved so failed. I think it's an odd test but if that's the case... I know the park brake is not great but any suggested improvements other than adjusting and hauling on the lever?
Old Mar 19, 2021 | 12:10 AM
Pegasus5150bako's Avatar
Re: Inspection park brake issue
You may want to try a different testing station. I find the Chain locations (i.e. Jiffy lube) are far pickier. I typically take mine to a drive through oil change station (Take5) to get mine done. Have never had to do this test.
Old Apr 4, 2021 | 03:42 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Agreed. From my recollection, procedure is to place the vehicle in drive with the parking brake engaged and see if it rolls. They should not apply the gas.
Old Apr 6, 2021 | 05:08 PM
maromaro's Avatar
Just had my inspected today and watched them apply the handbrake without hitting the gas
lonesomeloser
Brakes
Nov 20, 2009 06:21 AM
Gregg85IROC
Apr 5, 2008 04:36 PM
icebird_1981
Sep 20, 2002 04:25 PM
