NC Inspection ?
Car: 92 Camaro RS
Engine: lO3
NC Inspection ?
So My 92 RS is due for inspection next month and will be the first time since I've owned it ( only had it for like 2 months). Previous owner put a flowmaster catback on without the cat. Everything I read tells me I'll fail the inspection without cat. I know it's safety inspection only but I think they check to make sure all the emissions stuff is there.
I just wanted to check with somebody who had experience with NC inspections before I bought a new cat.
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Axle/Gears: 4th Gen 10 bolt posi / 3.43
Re: NC Inspection ?
Car: 86 Iroc 383 carb, 97 T/A WS6
Re: NC Inspection ?
You should be alright. It depends on where you take it but usually no one even checks that stuff on a safety inspection. Just take it to a small shop not a big chain store and you should be ok.
Seth
Seth
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Re: NC Inspection ?
Off topic question... If you run Ethanol gasoline do you have to run cats, anyone know?
Car: 92 Camaro RS
Engine: lO3
Re: NC Inspection ?
I don't think they can tell if your running Ethanol, correct?
So I would say yes, you would need cats. Assuming of course you needed cats for regular gasoline.
Elephantismo
Feb 13, 2019 12:51 AM
