South East Region Regional Board for South East Members.
Parting out 88 formula
Old Aug 22, 2008 | 07:30 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
88 Firebird Formula with T-tops.
Body is in okay shape.
Has 4" cowl
4th Gen rear end. 3.42 Posi 28 spline axles. ($500- $250 if you bring another rear to put in it's place)
Complete WC T5 conversion. Aluminum slave cylinder etc. I have both style Flywheels. $600
350 roller block with aluminum heads. (no induction) $200 (you pull it)
Carb setup/ Edelbrock performer RPM, edelbrock 1405 carb, new electric fuel pump and FPR, New air cleaner with top flow filter etc. comes with vac distributor. All for $400
3 sets of centerbolt L98 heads. $50 a pair.
Fiberglass spoiler $50
Set of 16" formula rims with kuhmo tires. $250
V belt setup $100 (comes with aluminum alternator brackets TPI alt, and all others)
Drive shaft steel $25
T-Top bag $25
Anything else you need. Call
Cale
251-209-1518
Wil sell entire car as is after I removed the exhaust, and interior for $1000 OBO.
Old Aug 22, 2008 | 08:15 PM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
Re: Parting out 88 formula
i am interested in the spoiler. is it a copy of the original or some different aftermarket style?
can you send pics, or post them here?
you can email me at searsautosuzy@yahoo.com too.
Old Aug 22, 2008 | 09:24 PM
Reputation7's Avatar
i Need the v belt setup.
also the rear end. i can get the rear end out of my car, if you can do the same.
its a drum 2.73 open rear end iirc.
Old Aug 22, 2008 | 11:06 PM
eagle's Avatar
would like complete tranny,with nuts and bolts.whats shipping to 10453.if u can please send some pics to rated.e@hotmail.com thanks
Old Aug 23, 2008 | 08:12 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
It is the fiberglass spoiler you would see on a standard base model firebird.
If you bring a rear end to put in it's place so I can roll it out we can work it out.
It is still in the car. If someone was interested, I would pull it out for a deposit. It is 100 percent complete.
Shifter.
Newly rebuilt trans.
VSS sensor, also have a cable one.
Corvette flywheel (1pc rms)
81 corvette flywheel (2 pc rms) (needs resurfacing
aluminum slave.
clutch only has 2000k miles on it. all the bolts are new.
trans has poly mount and poly torque arm busing installed already.
also have pedals if you need them
clutch reservior and mounting bracket
assoc hydraulics.
I also have a spare clutch master cylinder still in plastic.
Let me know
Cale
251-209-1518
Old Aug 23, 2008 | 11:33 AM
your in mobile?
Old Aug 23, 2008 | 01:01 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Yep.
Old Aug 24, 2008 | 11:21 PM
well gonna have to pass out on the stuff. may be picking up a d1sc + 100 shot LT1 z28 tomorrow.
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
