FS/Parting out 92 Camaro RS with GM crate engine and 5 speed Trans
I have a 1992 RS Im looking to sell or part out.
Here is a list of the good things it has
Gm performance crate engine part #12486041 350HO
Edelbrock performer intake and Edelbrock 1806 thunder series carburetor.
Aluminum radiator with flexlite dual fans
Hooker headers with Magnaflow exhaust
Also has a 5speed all gears work and clutch does not slip.
Engine runs great no oil leaks, ticking or knocking.
Has Z28 body kit on it.
Rear shocks are AcDelco Air shocks.
Currently sitting on 15" Cragers front size is 215/65/15 rear is 295/50/15
all tires hold air but tires are a bit old.
Now for the Bad
The body is straight but has a good amount of rust on the firewall. A few other areas of rust as well, a pillar, roof, windshield area and a bit on the underside of the rear quarter panels.
Upper dash panel is cracked
Tachometer, Speedometer and fuel gauge do not work.
Oil pressure , Volts and Coolant temp do work.
Key is broken off in the ignition, no extra key to open rear hatch.
The front seats are trash, frames rusted so bad that they where only secured by 3 bolts when i removed them.
Carpet is also trash due to the water that got in from the firewall.
Others things-
Interior trim is all there an in pretty good shape.
Also feel free to shoot me offers on prices and make inquiries if you need anything. I only have a few pics at the moment but can send individual ones if you are looking for something.
The Car is located in Longwood FL.
Now for the Bad
Others things-
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI
Transmission: Automatic
Re: FS/Parting out 92 Camaro RS with GM crate engine and 5 speed Trans
How much would you need to get from the transmission and the full kit to do a swap? (i.e. master cylinder, slave, pedals, etc.)
1 Post
Car: 1991 Camaro RS
Transmission: T5 manual
You wouldn't happen to be still parting out, would you? I need there gfx, maybe the motor and if the steering column is good I may need that too. To be exact I really need the whole car.
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
How high did the water get? Above the engine or all the way above the roof?
