South East Region Regional Board for South East Members.
Problems with my 89 camaro
Old Oct 8, 2018 | 08:57 AM
Marinemom101's Avatar
My 89 camaro was running perfectly then about 1/2 miles from home, it suddenly cut off as if I'd hit the ignition switch and wouldn't start back. It would turn over and wanted to start but wouldn't. At first I thought it was out of gas so I put gas in it and it still did the same thing, wouldn't start. It would turn over but still wouldn't start... It's a V8 and concerned that possibly the timing jump or the timing chain broke cause now when it turns over, it makes a racket...could this be the issue, plus if it is, would it cause the pistons/valves to meet causing even more problems, possibly with the crankshaft or cam ??
Old Oct 8, 2018 | 09:28 AM
Drew's Avatar
Re: Problems with my 89 camaro
Start at the basics, check for spark and fuel, check for error codes stored in the computer. You see a lot more thirdgens with a bad fuel pump or ignition module, than a mechanical sudden death.
Old Oct 8, 2018 | 11:56 AM
I had it towed to the garage below my house and went there this morning and we, the mechanic and I went over it...it almost started but then decided not to...after turning it over a few times and listening to the rattling, we more less confirmed it was the timing chain...he's running a diagnostic on it, then gonna look inside at the timing chain. If that's the problem, we'll take it from there...
Aggp18
Apr 3, 2005 05:40 PM
KED85
Oct 29, 2002 11:01 PM
WaynesRS
Aug 28, 2002 11:13 AM
oldblueZ
Jan 4, 2001 05:23 PM
oldblueZ
Jan 4, 2001 04:13 PM
