South East Region Regional Board for South East Members.
code 51
Old Feb 3, 2020 | 07:22 AM
LetzRoc1989's Avatar
Car: 1989 Iroc
Engine: 5.7
code 51
I own a 1989 5.7 iroc. 50 k original miles and I am original owner. Throwing a code 51. suggestions? Thank you
Old Feb 3, 2020 | 08:38 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: code 51
The memcal usually isn’t the problem. You should try ecm replacement first.
Old Feb 3, 2020 | 08:54 AM
Car: 1989 Iroc
Engine: 5.7
Re: code 51
where is ECM located and how hard to remove? THX again
Old Feb 3, 2020 | 09:01 AM
Engine: Lb9
Transmission: M20
Re: code 51
It’s located under the dash on a bracket on the passengers side.
there are two 7mm screws I think that hold the bracket to the dash frame.
Old Feb 3, 2020 | 09:14 AM
Car: 1989 Iroc
Engine: 5.7
Re: code 51
thank you. Thinking about using Module Experts for repair. Any idea if they are a good one? Thank again!
Old Feb 3, 2020 | 09:29 AM
Engine: Lb9
Transmission: M20
Re: code 51
I have never heard of them. You can get a reman ecm at RockAuto.com
the service is a 1227165.
https://www.rockauto.com/en/catalog/...computer),2896
if you find your car has a Hypertech memcal or a piggyback chip adapter I would think those could cause the code.
Old Feb 3, 2020 | 09:33 AM
Car: 1989 Iroc
Engine: 5.7
Re: code 51
car is still factory - I have never made any changes to it. Like to get a better chip and more performance.
While I am an old jet fighter mechanic, USAF - I am for sure not versed well enough in cars to mess with things too much. Thx again.
Old Feb 3, 2020 | 05:22 PM
BIRD91ZRAG's Avatar
Re: code 51
Does the car run ok, or did it start having issues?
Every vehicle I worked on that threw a 51 was running like crap and needed an ECM.
Old Feb 4, 2020 | 08:07 AM
Car: 1989 Iroc
Engine: 5.7
Re: code 51
what is weird, is it is very intermittent. When cold out, 40's here in South Carolina, runs great. Sporadic check engine, like it loses a cylinder, but keeps running. When hot out, more often and stays on. But will still run. always start as well. Thx for helping me.
malvex
Apr 30, 2017 11:55 PM
88 350 tpi formula
Jun 1, 2012 08:47 PM
dst80944
May 3, 2006 01:33 PM
Vikingbrew
Mar 10, 2002 09:52 PM
