South West Region South West regional discussion board.
T-56 install
Old Jan 8, 2003 | 08:51 AM
82Z28NAZ
Guest
Posts: n/a
T-56 install
Has anyone put a T-56 in their car? If so would they be willing to help with either install or advice. I am willing to pay for help with install.
Old Jan 8, 2003 | 12:06 PM
OMINOUS_87's Avatar
My friend put one in a 79 Z28. He could probably give some pointers on everything you need, and what you should modify before installing, something to do with third gear. But never in a 3rd gen.
Old Jan 8, 2003 | 04:23 PM
82Z28NAZ
Guest
Posts: n/a
ahhh ... scratch that... I'm going 200 4R
Old Jan 31, 2003 | 04:13 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Good choice. Let me know if you change your mind or need some help with that one.
Mike
Old Feb 4, 2003 | 02:14 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Eh, me too. Did a T56 into a 91 Z28, and am doing one in my car soon.
Old Mar 3, 2003 | 10:23 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
i have never done a t-56 swap into a third gen but i have pulled out t-5 and t-56 to some cluth work and the only thing that is diffrent form a t-5 and a t-56 is the crosmember and the speedo gear. if you have a t-5 in your car you put a t-56 in their and the only thing you would have to do it make a custom crossmemeber and find a way to make your speedometer work. I belive that you can use the same cluth master cylinder but you might have to replace the slave cylinder. the drive shaft and the torque arm are the same leanth. if you have an automatic you will have to cut a hole under your midle console for the shifter and an other hole in the firewall for the cluth.
Old Mar 3, 2003 | 11:03 PM
jmd's Avatar
jmd
mrt - good post.
The T5 master cyl. will not directly fit the T56 hyd. line. While if you extended the line, the master & slave would work w/ the 93-97 F T56, it's actually reasonable $ - wise to just buy the T56 master & slave setup, which do bolt directly into the third gen firewall.
Just thought I'd throw that out there for those wondering.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
gixxer92
Sep 1, 2015 04:32 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
