South West Region South West regional discussion board.
SLP Runners, BBK AFPR, and a B&M Tranny Cooler
Old Sep 19, 2003 | 05:14 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
Just ordered the SLP Runners, BBK AFPR, and a B&M Tranny cooler from LMPerformance.com. $389 Delivered.
Should have them by the end of next week. What kind of gains you guys think i will see?
Here's the mods I have already:
BBK 58mm TB, TB Bypass, Siamesed Ported Plenum, Ravin Muffler, Built 700r4 w/2000 Stall, A.I.R. Delete, Smog Delete, MAC Underdrive Pulleys, and Gutted Airboxes....
Yeah i think thas it. So what do you guys think?
Old Sep 19, 2003 | 08:33 PM
OMINOUS_87's Avatar
You might pick up a little bit in the upper rpm breathing but I wouldnt get your hopes up for anything more then that. The factory base is still gonna be a restriction.
Probably wont even feel anything on the but dyno.
Old Sep 19, 2003 | 09:15 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Actually, with port/siamese on the plenum, the runners, and port matching on the intake base, most places say its a 20-30hp gain, and with similar gains in torque.
Also, the AFPR is supposed to be good for a decent boost all by itself. There are dyno charts on this very site.
Q: What fuel pressure setting will give me the best performance?
A: The stock setting is 42 PSI. Much track testing has showed that any type of increase will greatly benefit both horse power and torque. Here's some dyno testing on a stock 350 motor which substantiates those claims:
42 PSI (stock) 46 PSI 50 PSI
RPM Torq HP Torq/diff HP/diff Torq/diff HP/diff
2250 237.7 101.8 254.9/17.2 109.2/ 7.4 275.0/37.3 117.8/16.0
2500 241.7 115.1 262.1/20.4 124.8/ 9.7 283.3/41.6 134.9/19.8
2750 241.5 126.5 275.2/33.7 144.1/17.6 297.0/55.5 155.5/29.0
3000 237.1 135.4 278.2/41.1 158.9/23.5 305.5/68.4 174.5/39.1
3250 233.8 144.7 278.9/45.1 172.6/27.9 311.3/77.5 192.6/47.9
3500 241.0 160.6 278.2/37.2 185.4/24.8 309.5/68.5 206.3/45.7
3750 246.6 176.1 283.4/36.8 202.4/26.8 303.3/56.7 216.6/40.5
4000 250.4 190.7 278.3/27.9 212.0/21.3 298.0/47.6 227.0/36.3
4250 251.6 203.6 272.5/20.9 220.5/16.9 289.1/37.5 233.9/30.3
4500 253.5 217.2 257.3/ 4.2 220.5/ 3.3 277.0/23.5 237.3/20.1
4750 245.0 221.6 242.1/-2.9 219.0/-2.6 266.4/21.4 240.9/19.3
5000 227.6 216.7 225.0/-1.4 214.2/-2.5 237.8/10.2 226.4/ 9.7
It shows that by increasing the fuel pressure to 50 PSI, results in maximum torque increase of 58 ft-lbs (along with a much flatter torque curve) and a maximum horse power increase of 19 HP over stock. 46 PSI also provides a noticable increase which should work well for day-to-day street driving. An adjustable fuel pressure regulator (see Chap 5.2) is required to increase the fuel pressure.
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Royal_Z
Sep 30, 2015 08:45 PM
