South West Region South West regional discussion board.
Cutouts
Old Nov 25, 2003 | 03:40 PM
GearDrive63's Avatar
Car: 89 Camaro RS
Cutouts
they sound pretty good eh? any suggestions on what kind i should get? i could make a pull cable for them, or should i just go with the lugnut ones?? or are the electric ones reallyt worth the money?? anyone want to do some welding for me?
Old Nov 25, 2003 | 03:54 PM
82Z28NAZ
Guest
Posts: n/a
you could make some pretty cheap.
I made mine from exhaust pipe stock, a header flange, and a piece of 10 gauge steel.
Old Nov 25, 2003 | 04:15 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
I got mine for my old 86 from summit for like 25$
Old Nov 25, 2003 | 04:23 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
well if you have the tools to cut your own pipes you can have them welded up. otherwise you can buy them pretty cheap $28 from jegs or summit $25 spinoff lugs. electric cutouts are expensive but worth it, i guess. what do they cost like? $190 or $200 for a 3". when i get some time i'll be trying my hand at making some servo-assisted electric cutouts.
Old Nov 25, 2003 | 05:08 PM
Car: 89 Camaro RS
well i want to go with those $25 lugnuts ones, Lopers has them in stock for $20 so.. only thing is how much of a pain in the *** is it to get under the car and open them?
Old Nov 25, 2003 | 06:29 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Its not hard at all to open it, I did it every morning before I left for school I had mine where my cat used to be so it allowed for easy access.
Old Nov 25, 2003 | 09:42 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Check out this thread: https://www.thirdgen.org/techbb2/sho...hreadid=211040
86White_T/A305
Mar 6, 2016 01:48 PM
formula_novice
Sep 5, 2015 03:58 AM
Josh 91RS
Jan 22, 2001 01:23 PM
Mike Harvey
Dec 7, 2000 02:52 PM
