South West Region South West regional discussion board.
Emissions Testing
Old Apr 20, 2005 | 01:32 AM
90_WS6_Formula's Avatar
Car: 91 Z28
Emissions Testing
Has anyone gone through emissions lately? I went today and the 'Bird passed but the NOX was borderline. Anyone know what causes this? As for everything else is concerned it was blowing roses out the tailpipes.
Old Apr 20, 2005 | 08:36 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Check for proper EGR operation. That plays a big part in low NOx readings.... Gimme a call sometime, Ill give you a hand with it. I just got my Chevelle through. If that passed, just about anything will.
Old Apr 20, 2005 | 10:58 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I just sent both of my cars through. Both passed. But the T/A is throwing an EGR code. I guess the EGR valve has to be replaced again. What a pain, taking off the plenum.
Old Apr 20, 2005 | 11:00 PM
azvolfan's Avatar
Forgot to say, it's an easy job on the LO3. The EGR sits right on top. On the TPI engines it's under the plenum.
Old Apr 20, 2005 | 11:45 PM
Car: 91 Z28
get the fel pro TPI gasket set the ROL set is junk but it's much cheaper
Car: 91 Z28
here's a dumb question... but... how do you check that?
Old Apr 21, 2005 | 12:24 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
EGR? HSRs don't have EGRs.
Went through 4 months ago. Just had to tweak the fuel pressure and the initial timing.
Old Apr 21, 2005 | 06:56 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
another member posted this
I don't remember who. He was going to school & it came straight from his school book.
Emissions failure & possible causes
Excessive HC emissions may be caused by:
ignition system misfiring
Improper ignition timing (retarted)
excessively rich air/fuel ratio
low cylinder compression
defective valves, guides, or lifters
vacuum leaks
Excessive CO emissions may be caused by:
rich air/fuel mixture
dirty air filter
faulty injectors
higher-than-normal fuel pressures
defective system input sensor
Excessive HC and CO emissions may be caused by:
plugged PCV system
stuck open heat riser valve
AIR pump inoperative or disconnected
engine oil diluted with gasoline
Lower-than-normal O2 readings may be caused by:
dirty air filter
faulty injectors
Restricted PCV system
charcoal canister purging at idle and low speeds
Lower-than-normal CO2 readings may be caused by:
leaking exhaust system
Higher-than-normal O2 readings may be caused by:
an engine misfire
lean air/fuel mixture
vacuum leaks
lower-than-specified fuel pressures
defective fuel injectors
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Eric-86sc
Sep 28, 2015 11:37 AM
raymondandretti
Sep 27, 2015 06:43 PM
