South West Region South West regional discussion board.
sooo, its not the fuel pump
Old Jun 27, 2005 | 09:49 PM
SchwarzCamaroRS's Avatar
yeah, story of my life... its not the fuel pump, but it still wont start... for some odd reason... I know its not the pump cuz while it was up on jacks, i had the plug wires off, so i reconnected them, poured some gas down the TB and fired it to make sure i connected the wires right, and i figured, ok, its gunna shut off after about 10 secs... nope.. injectors fired perfectly and she was alive!!! i didnt believe it, sooo i shut it off and re-fired, no gas down the TB this time... 1st try it fired... so i figured, YAY just a dumba$$ fluke and my car is fixed... so i drop it down off the jacks, turn the key and... nothin... crank, crank, crank till the cows come home... the injectors are about a year old so i know its not them... wtf????
Old Jun 28, 2005 | 02:12 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Why couldn't it still be the pump? If it is only firing ocasionally then the pump is going bad. As far as I know some pumps will do that and others will just quit. If you have spark then it's a fuel problem and vice versa. You could have a bad wire. Mine has gotten fried once before. Follow the wire from the gas tank to the front of the car and make sure its intact.
Old Jun 28, 2005 | 01:30 PM
it fired EVERY time i tried it up on the jacks, i had a couple fun revs too cuz i cut off the muffler (i wanted to hear it better ) i slowly applied throttle till i got to like 4500rpm then i let off, let it go down to idle, then i just jammed it to the floor and wrapped it up to like 5k and it returned to idle no prob.... it idled for a good 7 mins before i quit celebrating and shut it off. all the wires are fine, i checked those before i ran out and bought the new pump... i have spark for sure... could still be the pump though eh? crap...
Old Jun 28, 2005 | 02:11 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
ok im going to ask the dumb question to get it out of the way. If it was up on jack stands, im guessing the front end was still on the ground? If thats true how much gas is in the tank now that its sitting flat?
Old Jun 28, 2005 | 02:27 PM
1/4 tank... lol and it was on 4 jacks... lol so it was level
Old Jun 28, 2005 | 02:30 PM
im thinking fuel pressure... i just got it stumbling again with gas down the runners and the damn injectors were working... well... dripping... not spraying... changed PROMs and it didnt do anything...
Old Jun 28, 2005 | 02:36 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
You should prb get a fuel pressure guage, or ask someone to come over with one ( i dont have one ). I would check the fuel pressure coming out of the pump, should be at least 38 PSI. Then if thats ok go down the line, and check it after the fuel filter.
Old Jun 28, 2005 | 02:41 PM
anyone know if autozone or checker rents those out?
Old Jun 28, 2005 | 02:43 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
Checker doesnt and they cost like 50 bucks
Old Jun 28, 2005 | 02:46 PM
yeah, i just checked online... sheisse!!!
Old Jun 28, 2005 | 02:53 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
He's got TBI, it doesn't run as high as TPI fuel pressure.
Old Jun 28, 2005 | 02:54 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
Good point didnt even think of that... damn TBI's lol
Old Jun 28, 2005 | 03:04 PM
how much pressure am i supposed to be running?
Old Jun 28, 2005 | 03:38 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
I don't know, I stay away from Toilet Bowl Injection. I think it's around 14-20 PSI, though.
Time to whip out that button.
Old Jun 28, 2005 | 04:43 PM
cool, thanks
Old Jun 28, 2005 | 09:18 PM
fuel filter changed... no cloggage reported... still no fuel to the injectors... i dont want it to be the pump, but im sure it is...
Old Jun 28, 2005 | 09:48 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Uhh........since you had it on the jacks already and already cut the exhaust........why didn't you just change the pump anyways? You're on a mission to get more power out of that thing, and your more than likely going to need the extra fuel anywho....
Old Jun 28, 2005 | 09:50 PM
true, true...
Old Jun 29, 2005 | 03:37 AM
soooo, it was the fuel pump, just got her done and buttoned up and MAN!!! she's back for business!! thanks for everyone who helped me along the way...
Old Jun 29, 2005 | 12:36 PM
Your welcome...LOL
Old Jun 29, 2005 | 01:08 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
The bill's in the mail.
Now to do something about that Toilet Bowl on your motor.
Old Jun 29, 2005 | 01:46 PM
TBI for life!!!!!!
Old Jun 29, 2005 | 02:04 PM
lol, i just washed her up real nice and something not so cool happened... hot car + cold water = windshield thats cracked in half.... super...
edit : I found a place here called Phoenix Discount Glass - mobile service, full install and 1 year warranty for $189
Old Jun 29, 2005 | 03:45 PM
90RS305's Avatar
They need a clapping smilie that rolls his eyes at the same time
Give me a call later today David...
Old Jun 30, 2005 | 12:47 AM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
So it was the pump after all
Well Look at it this way you shouldn't have to change it again for a long long time if ever
So Get that exhaust on there and let head out to Firebird and tear it up
Old Jun 30, 2005 | 02:02 AM
or no exhaust hehehehe, i dont think they'll allow it.. haha. i wanna get the headers and stuff on before i re-do my exhaust cuz i wanna go 3" all the way
Old Jun 30, 2005 | 07:19 AM
You're allowed open headers...
Old Jun 30, 2005 | 12:26 PM
i have open CAT i guess you could say... its full exhaust minus a muffler... lol, i guess thats kinda like open headers...
Old Jun 30, 2005 | 06:55 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
how hard was it to get to the fuel pump once you had the exhaust cut?
congrats on getting it fixed.
Old Jul 2, 2005 | 02:29 AM
it was about 4 hrs, i halfway dropped the axle, just took off the shocks and springs. Id do it again if i had to... just tedious and aggrivating trying to finagle the tank down with a non-flexible filler neck
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
