Does anyone near Kingman have a Steering Column???
Car: 1991 Camaro RS
Engine: L03 305 TBI, nearly stock
Transmission: 700R4, stock
Axle/Gears: 3.23 out of a V6/5 speed car.
My steering column isn't just loose, the bearings are shot too, and any big bump knocks the ignition switch out of whack!
I'd almost say I'd prefer a non-tilt column, but any solid column will do...
I don't have alot of $$$
Can someone help a guy out!
Car: 1991 Camaro RS
Would have been a good choice, but someone beat me to it!
All he has left is one Berlinetta column.
Thanks!
Maybe Kingman Kar. I'm just not in the shape to crawl around wrecks these days - bad back. I was hoping someone had an extra...
Thanks!
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
just don't go to Dan's junk yard.Especially if you have to deal with the guy Dale that works there.He won't like to sell anybody fbody parts because he wants to use them on his POS buick.Screw that guy, He's a ****.
Car: 1991 Camaro RS
He's the guy who told me they only had one column, and it was for a Berlinetta. I know that place is his personal parts source also!
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
If the reason for the looseness is the tilt-column, I can help, having went through that nightmare on my IROC. I have the special tools and an illustrated walk-through. Too bad GM didn't lock-tight those four screws in the column...
Car: 1991 Camaro RS
I've definately been through that ordeal - a few times! Lost my reverse torx socket though...
However, in this case, the upper column is tore up. the bearings are shot, and the housing is hollowed out.
Thank you though!
...and yes, a little lock-tite on GM's part would have saved alot of headaches!
Thank you though!
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Last I checked at pick-a-part, there were a lot of thirdgens with still mostly complete interiors. They had two hollowed out IROC's, but quite a few usable birds and base model camaros. I don't remember ever seeing them have a berlinetta. Good luck on the search.
Car: 1991 Camaro RS
...He didn't have the car anymore, just the column, and some assorted parts...
However, I did find a real good on on ebay, $35.00 + $20.00 shipping. Non-tilt, but in excellent shape, with wheel!
I think I did all right! I won't really miss tilt wheel.
Thanks guys for all your help and responses!
i haven't gotten one yet Ed.What's up?
Engine: 5.7
Doesn't matter to me.let me know when and I can either come over or you can come to my house.
sjorgens
Oct 1, 2015 07:54 PM
