South West Region South West regional discussion board.
Help passing Emissions..
Old Oct 26, 2009 | 06:19 PM
rockstar08's Avatar
Car: IROC-Z
Hi Today my IROC-Z 350 TPI failed emissions testing
The results were:-
Hydro Carbons HC 2.40/1.00 FAIL
Carbon Monoxide CS 14.9/12.00 FAIL
Oxides of NOX 1.81/250 PASS
The air filter is clean, its had a recent oil change (mobil 1 0w30). The ECU is reporting no codes. I also took it for a long drive before testing.
I have an ALDL cable I recorded a session with TunerPRO RT, if that helps?
Can anyone advise on how to get HC & CS down to legal values?
Old Oct 26, 2009 | 06:44 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Help passing Emissions..
New Magna flow cats and tune it lean lean. Still have the air pump on it?
Old Oct 26, 2009 | 07:05 PM
rockstar08's Avatar
Car: IROC-Z
It still has the air pump, all stock AFAIK. What magnaflow cat models do you recommend? Currently has the dual setup. I really need to keep the cost down if possible..
Old Oct 26, 2009 | 11:41 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
Did you have the A/C on, it makes a big differince.
Old Oct 27, 2009 | 02:12 AM
rockstar08's Avatar
Car: IROC-Z
Nah, the AC was turned off.
I read that adding alcohol helps, but I don't know what kind to use?
Old Oct 27, 2009 | 03:11 PM
AZ_James's Avatar
I had similar numbers on my last test but my HCs were up around 4 i think. Prior to even getting this test, I had put in new plugs, cleaned TB, New O2 sensor, new oil, dist cap, rotor, new cat (had a straight pipe before).
I did not have the tools or knowledge for timing adj. I took it to a local shop who did emissions work. $80 diagnostic fee and it was fixed. I believe they fixed a vac leak and adj timing (not sure how much though). They also had the equipment to measure the exhaust and ensure I was going to pass before I left the shop. Best $80 i spent.
Old Oct 27, 2009 | 11:27 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
I had to use 3 large bottles on 1/2 a tank, drive it around like 1/2 mile or so, then run the test, gas up immediately after to water it down
Old Oct 28, 2009 | 01:00 AM
rockstar08's Avatar
Car: IROC-Z
AZ_James, do you remember the name of the shop you used? I'm over in Chandler.
Old Oct 28, 2009 | 11:18 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
HC's & CO's being up means to much unburnt fuel is rolling out your tail pipe. Check your timing and change your plugs if they haven't been done in the last year or so.
Old Oct 28, 2009 | 06:52 PM
AZ_James's Avatar
I used AZ Auto Repair in queen creek on crimson & ocotillo. Might be a little far out of town for you. I used them since they had done quite a few emissions jobs and had a good success rate as shown on the AZ Emissions web page.
Might want to check out http://www.myazcar.com/ and click the locate a repair facility link on the right. It will let you filter by zip and find a shop near you as well as tell you how many repair jobs they have performed in which the Emissions paperwork was completed and turned back in at the testing center.
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
