Southern California Area Southern California Members.
Help with A/C
Old May 17, 2002 | 11:44 PM
sanchez's Avatar
Car: 1990 Iroc-z G92
Transmission: 5 Speed
Help with A/C
my compressor has blown its gaskets. And it will cost me alot of $$$ to fix it .
I was wondering if Any one knows If there is any way to convert my system with the parts from a fourth gen so it will use R-134A
:hail: pleeeeeeeese some one help its hot in Texas
Old May 18, 2002 | 01:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I got a compressor (that turned out to be a new one) from Thomas ***'s House of Camaro salvage yard. Do a search on here and you'll find his info, I dont have it handy. He's in SoCal and a great guy to deal with.
Old May 19, 2002 | 06:07 PM
Russ-So Cal's Avatar
There isn't anything special you need to do to convert to 134a. Virtually all of the discount stores as well as any auto parts store carry kits. The secret is to use poly esther oil instead of the PAG oils that the factory puts in the new cars. The poly esther oil (poe) are much more forgiving of mixing with the mineral oil used with r12.
Old May 19, 2002 | 06:18 PM
sanchez's Avatar
O.K well that sets it straight . thanks very much
i just convert and finaly own a car with working AC
Old May 20, 2002 | 12:57 AM
big green monster's Avatar
You know, Ive been having a problem with my pump!!! I just had the whole system replaced with new parts about a year ago, (blew the pump on the drive from Tucson to Austin, yeah it was hot in June man, I feel you SANCHEZ) ANyway, I had it converted to R134 at the same time. After about six months of limited use, when I turn it on now, it bears down on the motor really bad , not to mention the gut wrenching low hum it puts out when the pump actuates. This is only at idle or cruising around town though. It does okay on the highway. Any help???
Old May 20, 2002 | 07:04 AM
sanchez's Avatar
it helps alot I have decided to bite the bullet and convert so it is cheaper to recharge.incase of future problems
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
