brakes of a camaro
brakes of a camaro
what is the biggest rotors and pads that i can put on my 89 conv. camaro without changing too much? thanks jason :lala:
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The 1LE setup is factory and comes with 12" rotors and dual-piston calipers. Pricing goes anywhere from $600 to $1200. Its offered from a few different companies.
After that you have the 13" Baer kit which requires 17" wheels, I think. Its about $1000-1200.
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Yep, ditto what Kevin said.
If you buy a "ready-to-go" 1LE kit expect to pay around $900. You can piece one togther cheaper. That's what I'm doing.
The Baer kits are around the $1200 mark.
Zachattack0925
Aug 12, 2015 09:52 PM
