Southern California Area Southern California Members.
Anyone Know where to get a Motor?
Old Dec 1, 2003 | 03:05 PM
ProjectPontiac's Avatar
Car: 1989 FireBird
Transmission: 5-speed
Im looking for a cheap perfomance engine for my car, I have a 1989 Firebird that im trying to rebuild and im not really wanting to put the stock engine back in.
Anyone got info?
Thanks...
Old Dec 1, 2003 | 05:15 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
I have a vortec motor from a 97 Seirra, would need the SDCP intake manifold for tuned port - but as you can tell by Don's awesome results its a solid performer!
write me if you are interested:
rminarik@hotmail.com
Old Dec 1, 2003 | 05:37 PM
shotgun's Avatar
Car: 89rs
I wonder if this engine would be smog legal?
http://www.sdpc2000.com/cart.asp?act...=1577&pid=9009
Old Dec 1, 2003 | 08:30 PM
Russ-So Cal's Avatar
Technically it is not smog legal, but if you install a Corvette style egr, it will pass. Most smog techs just look for the right smog parts installed on the engine, and run it on the roller to see if the numbers come up good. They just can't keep up with all of systems on the market to be sure it is legal, so if it looks stock, or has a carb eo#, and has all of the pieces that the computer from Sacto says it should have, it passes visual, then it just has to make the numbers.
Old Dec 1, 2003 | 10:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There is no such thing as "cheap" and "performance" together. "Cheap" and "rebuild" together usually are followed by "broken" and "walking home". Good luck.
Old Dec 2, 2003 | 12:23 AM
demonchild's Avatar
i hate the fact that vortecs are not made with the provisions for an EGR. i think this question was asked, but does the zz4 heads have the provision for an EGR?
Old Dec 2, 2003 | 02:00 AM
Kevin91Z's Avatar
The ZZ4 heads are the same as the Corvette L98 heads, which do not have any EGR ports. Hence the need for the "Corvette EGR setup".
Old Dec 2, 2003 | 02:42 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Too true. One of my favorite sayings is:
1) Speed
2) Quality
3) Price
Pick two.
Old Dec 16, 2003 | 09:46 AM
DriftaGMCamaro's Avatar
Car: 1989 Camaro RS
Engine: L03 TBI V8
Transmission: M5
I WANNA LS1!!!!!!!!!!! they're like what 2500? plus computer.. custom engine mounts.. oh man WHAT A BIG price tag
Old Dec 16, 2003 | 12:48 PM
Car: Yes...
A used LS1 might come in at $2500, but a new crate version runs like $5k. Add on the computer, wiring harness...etc and it's gets real expensive.
http://www.sdpc2000.com/cart.asp?act...id=128&pid=109
Old Dec 16, 2003 | 03:54 PM
demonchild's Avatar
ok, i thought of some specific questions that maybe someone can answer.
1) the vortec heads came stock on some year trucks. what kind of egr did those trucks have and how did the valve work? also, compare the amount of exhaust that was allowed to pass through that style EGR compared to the stock f-body EGR say off of a q jet carb.
2) since the corvette EGR it tapped into a primary, is there anything between the tapped primary and the carb (yes CARB, i wanna know for my application) that regulates the gas flow?
3) a little more broad question: exaclty what components make up a corvette EGR system and how do they work as a part of the system.
if you dont wanna answer these questions, please dont respond with a flame telling me how much i dont know. i already know that.
Old Dec 16, 2003 | 11:34 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
You.. me... and a million other people out there!
Old Dec 16, 2003 | 11:41 PM
12secSS's Avatar
I have an LS1, it came factory equipt with the optional Camaro SS.
Old Dec 17, 2003 | 12:52 AM
Car: 1989 Camaro RS
Engine: L03 TBI V8
Transmission: M5
CAN"T I JUST THROW ON A TPI on my LO3
Old Dec 17, 2003 | 08:28 PM
#1-Truck engines don't have egr. That is why it is illegal to install a truck engine in a car, and why the Edelbrock and other aftermarket efi units that are smog legal in a truck are illegal to use in a car.
#2-I'm not sure, but I think there is a solenoid valve between the exhaust manifold and the intake manifold. On a carb the egr would tap into the intake manifold below the carb.
#3- I think the components consist of a tube from the exhaust manifold to the egr solenoid, the solenoid, and a tube from the solenoid to the intake manifold egr port.
Old Dec 17, 2003 | 10:30 PM
demonchild's Avatar
i made this thread to find out about the corvette EGR. i copy/pasted what russ so cal said, but if anyone else wants to put in what they know heres the link
https://www.thirdgen.org/techbb2/sho...hreadid=215068
know to get back to this threads topic...
Old Dec 18, 2003 | 07:43 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
They are L31 heads. 96-98
Old Dec 18, 2003 | 02:34 PM
89transam's Avatar
How about a 99-02 Camaro/Firebird 3.8 V6 for $350?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2449334932
Old Dec 18, 2003 | 10:14 PM
Kevin91Z's Avatar
Truck engines DO have EGR valves. What they dont have is the AIR tubes and smog pump.
The trucks with Vortec engines have an external EGR hookup on the driver's side.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
