stealth ram
Car: 90 T/A GTA
Engine: 350 tpi
yeah it seems like a good intake. but one problem it's not smog legal, but who cares i don't need to worry about smog i can get around that. it seems alot cheaper then porting your intake or going with a stealth ram or a mini ram.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: stealth ram
Originally posted by blaznbrd
hey what do u guys think of the stealth ram? is it worth the $500?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Re: stealth ram
Originally posted by Kevin91Z
Its no better than stock for a stock engine, but if you have a better set of heads and a better cam, then its worth it. Good luck getting it thru the smog check.
