Southern California Area Southern California Members.
can i use 416's with a 355?
Old Feb 17, 2004 | 12:40 PM
KiLLJ0Y
Guest
Posts: n/a
i just got a rebuilt 355.. i have a set of heads that have just come back from the shop that i was going to use on my 305.. the heads are 416's and i had 1.94 and 1.60 valves put in, as well as a mild port job. the heads are 58cc's
can i use these on my new 355? i really dont want to buy new ones.
also is a 93LT1 cam better than the stocker? i have one , and the engine is still on the stand, so i didnt know if i should change it out or not.. thanks guys
Old Feb 17, 2004 | 03:07 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It depends on what pistons the 355 has. If they are flat tops w/valve reliefs it would be almost 11.0-1. If they are dished like stock it will be a little over 10.0-1 and that would be pushing it to the limit. 91 octane would not be enough with steel heads.
Yeah, the cam is better than an L03 or L98.
Old Feb 17, 2004 | 03:15 PM
KiLLJ0Y
Guest
Posts: n/a
yeah the pistons are flat tops with the valve releifs.
DAMN IT!!
k so it looks like i need to get some L98 heads then? what is the CC i need to be looking for?
does using a thicker head gasket make any difference? i really wanted to use these heads(416;s) but it looks like i wont be able to then, right Don?
Old Feb 17, 2004 | 03:24 PM
Dyno Don's Avatar
It would not be a good idea.
You need 64cc heads and a .051 gasket to keep it at 9.8.-1.
I would use the GMpart #12557236
Old Feb 17, 2004 | 04:12 PM
KiLLJ0Y
Guest
Posts: n/a
i dont suppose you have a set of heads that are ready to go, do you Don?
Old Feb 17, 2004 | 06:43 PM
305LG4Cutlass's Avatar
What about 416's on a 79 LM1 350 that had 8.2:1 cr stock? What would the cr be?
Old Feb 17, 2004 | 11:50 PM
12secSS's Avatar
Question Originally posted by 305LG4Cutlass
LM1s use 76cc heads ...
Answer Originally posted by Dyno Don
... they are dished like stock it will be a little over 10.0-1 and that would be pushing it to the limit. 91 octane would not be enough with steel heads.
I would recommend that you use 4.00" bore heads with any 4.00" bore based engine. Too many hidden problems from just slapping on 305 heads on a 350 engine.
Old Feb 18, 2004 | 12:25 AM
Dyno Don's Avatar
That would be around 9.8-1....barely make it on 91 octane
Old Feb 18, 2004 | 01:12 PM
KiLLJ0Y
Guest
Posts: n/a
are there any casting #'s i should avoid? i found a company that has 64cc heads for a 350... what #'s should they be?
Old Feb 18, 2004 | 02:08 PM
Dyno Don's Avatar
Heads
#1083's are L98 '87-'92 for camaro.
#191-193's are L05 350 for trucks.
Old Feb 18, 2004 | 04:20 PM
KiLLJ0Y
Guest
Posts: n/a
well its a good thing i asked.... the shop said the heads were 193's
im just going to say screw it... and buy vortec heads from Jegs. yeah i know... gotta change the intake as well..
does Scoggin Dicky have 87TPI manifold in vortec style?
Old Feb 18, 2004 | 04:58 PM
KiLLJ0Y
Guest
Posts: n/a
k screw that idea... im not spending over 400$ on a damn intake..
anyone have L98 heads please?
Old Feb 24, 2004 | 11:24 AM
Dyno Don's Avatar
1083 heads (L-98's)
Dave...
I found you a set of heads...let me know if you still need them.
PM me.
Don>>>
Old Feb 24, 2004 | 07:01 PM
KiLLJ0Y
Guest
Posts: n/a
thanks Don, but i just scored a set from a list member on saturday... Thanks Fernando!!
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
mike22115
Sep 28, 2015 04:49 AM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
