Injectors
Car: Assorted
Engine: Various
Transmission: Manual and Automatic
Injectors
Well I dont think I can nurse the little red car for very much longer. Its getting really hard to start when its hot and I know its the Injectors leaking down. The car runs fine other than that. The problem is I hate to spend the money on 19lb injectors when I want to put a 350 in and I'll just have to turn around and buy 22lb injectors all over again. The Motor is getting tired and I know its not going to last forever. Any suggestions or anybody with 19lb injectors that are good and you want to part with them.
Car: Moving...
Engine: Running...
Transmission: Shifting...
I think I might have the stock set from my IROC, 350 injectors but they worked fine when they were removed. I will look around the garage and let you know
Car: Assorted
Engine: Various
Well the reply I got from Rich at cruzinperformance leads me to believe that I just may be better off to buy the Accell Injectors from Jeg's for $229 and be done with it. I was hoping that everything would last long enough to get the engine changed, but it does not look that way now. Thanks for your help and input just the same. Anybody ever use the Accell Injectors.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Lang:
I have 7 from my '90 TA that are good, you're welcome to them.
thejimsterz28
Sep 15, 2015 04:37 PM
but I am not sure if they're good or not. Let me know
