Southern California Area Southern California Members.
Data Master Program
Old Dec 12, 2004 | 05:08 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Data Master Program
I don't know how accurate the Data Master program is on the Dyno portion put here is what mine is putting out in 3rd gear. I had to shut it down @ 90MPH do to traffic. This was about 4800RPM in 3rd gear. Anyways I was getting spark retard and you could see it in the chart. Don was riding with me and I forgot to factor his weight in. I put the total weight of the car at 3700. It probably should have been more but here is what it said for that run.
348.5 HP @ 4323 rpm. 425.1 torque @ 4266 rpm.
Without the spark retard and a full run to say 5500 RPM things look promising. With the spark being pulled back that is why the high HP reading was at 4323 rpm instead of at a higher rpm. Allen
Old Dec 12, 2004 | 06:08 PM
KiLLJ0Y
Guest
Posts: n/a
damn Allen.. thats some awesome HP and Tq.
are you using stock heads?
Old Dec 12, 2004 | 06:18 PM
Car: 1989 GTA
Engine: 369 TPI
Hi Dave
I'm using Trickflow heads. I believe the numbers are calculated at the flywheel. Looks like 300+ RWHP is very doable. At least with the Data Master the info is on my car and not theory. Allen
Fireslash
Apr 11, 2016 06:43 PM
jaridjohn
Oct 5, 2015 07:01 AM
bjpotter
Oct 4, 2015 07:48 PM
ULTM8Z
Oct 2, 2015 01:25 PM
usafirebird
Sep 29, 2015 11:58 PM
