All Quiet On 3RD Gen Front
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
About as quiet as I have seen this board.
Anyways my modified plenum is 90% done. I would say the runners are about 85% done. Like I said earlier this is taking a lot more work than I thought and longer. Hopefully with all the time and money spent I will see some improvement. If not it will be a disappointment with all the work I have put in on the mods.
I did not go as far a Jerry went and I can imagine how much work he put into the runners for Don and Kevin. I can see why he does not want to do it again.
Going camping this comming weekend so won't be able to finish up. Maybe the following weekend I can finish the project. Need to get the runners and plenum bead blasted to make the work look factory. Then I'll have to check the air fuel ratio. If the air intake is improved it might lean things out. Than again with the MAF maybe not.
Allen
Anyways my modified plenum is 90% done. I would say the runners are about 85% done. Like I said earlier this is taking a lot more work than I thought and longer. Hopefully with all the time and money spent I will see some improvement. If not it will be a disappointment with all the work I have put in on the mods.I did not go as far a Jerry went and I can imagine how much work he put into the runners for Don and Kevin. I can see why he does not want to do it again.
Allen Last edited by 1989GTATransAm; Feb 15, 2005 at 09:26 PM.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Work in progress
Anxious to see the modifications.
I think I have discovered the culprit in my CAI restriction and will be implimenting the fix soon. I have located the materials to do so, at considerably less cost than the cast elbow.
Car: 1989 GTA
Engine: 369 TPI
Hi Don
I agree that the intake system is where the power is going to be found in our cars with the present mods. Glad you found a cheaper solution. I truly believe you can get at "least" 320RWHP with your present setup.
I'm also going to clean up the MAF inlet and exit transition pieces that I made. I think I can make them flow a little better. Looking for every way to increase CFM.
Trying to reduce turbulance and let the air flow as smoothly as posible. CFM=HP. Hehehehe. Allen
Trying to reduce turbulance and let the air flow as smoothly as posible. CFM=HP. Hehehehe. Allen Yes it sure has Allen.. Everyone must be turning wrenches.. My fuel system is half way done.. But I still have alot of other work to do.. And esp.. Getting everything back together.. Im going to through in another pump in the tank also.. I already got it.. Acdelco.. Good enough to stay in there until it's ever used again..
Hope all works out for you with your runners.. if your making better flow then there must be a gain..
Don How did that clutch go? From Fontana.. Is it working?
Clutch
Oh yeah, it works fine but I need to install a steel (heavier) flywheel to launch with. My runners reduced too much torque down low.
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
thats because everyone is working on their "DEEEEEEP BLACK" projects
such as my LT1 manifold, and Home Depot 3" intake.
Originally posted by RWB____s
Don
I have a nice heavy flywheel laying around some where.
Don
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
I have radically changed the direction of my car. I should be selling off the parts I no longer need in a couple months once I have time to finish what I have started. Mike can verify that my "competition" will be dissapointed with the direction I have taken my car
Right Jerry?
Engine: 3.6L
Originally posted by Dyno Don
Your competition (Jerry) will be more than anxious to take you on with your new direction. LOL
Right Jerry?
Right Jerry?
My competition is Vincent, YOU, and Randy. We all have pretty mild combo's, mine just ahppens to be the fastest, or at least have the fastest posted time. Just because the bunny is faster, albeit somewhat untouchable, than you guys is no reason to bump it up a class, right?
Car: 1989 GTA
Engine: 369 TPI
I should have named this post "DEEP BLACK" with all the wrenching going on.
Like Brandon said this should be an interesting year. Allen
Like Brandon said this should be an interesting year. Allen Joined: May 2002
Car: 1983 Daytona Trans Am
Engine: LG4
Like Brandon said this should be an interesting year. Allen Originally posted by 1989GTATransAm
Like Brandon said this should be an interesting year. Allen Joined: Jul 1999
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Speaking of agendas....
Hey James, I'll be your Huckleberry... However my car always seems to fall apart the week before race day.
Engine: 4.3 Turbo
Transmission: 4L60
Re: Re: All Quiet On 3RD Gen Front
Originally posted by JERRYWHO
Just doing lots of work and getting ready for James and his new stroker motor.
Jerry
Jerry
DOM DOM DOOOOOMMMMMMMM!!!!!!!!!
the plot thickins...
course non of you will be able to even handle my combo.. im runing 900rwhp with 1000rwtq.. normally asperated.. stock rear end.. yeah i should be clicking off 6's.. with 1.00 60ft's
yeah but i think im going to tear it down and rebuild it better.. since im such a great driver and always go to the track.. they call me Dave "Grumpy" Fisher... you know you heard the name.. dont lie
C'mon Don, who are you fooling? Jerry has full on race car complete with several hundred pounds of weight reduction, a roll cage, battery cut-off switch, etc.
Sorry sucker Jerry is your competition
Engine: 3.6L
Engine: 3.6L
You are the one who moved up a class...just because you didn't do all Jerry did, that's your fault.
Engine: 4.3 Turbo
Transmission: 4L60
which is what makes time travel possible...
did you happen to upgrade to a Mr. Fuzion?
do you see any serious sh*t when you hit 88mph?
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I'm so so sorry James for beating up on you in the pass year or so. I didn't know whipping your *** like I did would make you spend money to change your engine combo. My bad!
Engine: 3.6L
How have you beat me up? You've NEVER had a good honest look at my car on the street so you can't rely on that...or maybe you can
I hadn't changed anything in a couple years (same combo since 2003), so why does a couple hundred bucks (net) on a few small tweaks scare you?
Looking at the list it looks like you still need to find a several more seconds to catch up to Mike's fastest posted time.
Engine: 3.6L
Originally posted by injdinjn
James changes his mind more than any woman I ever met.
Aw shut up....your're starting to sound like an old woman....just bring it on out and take on Jerry like a man
Engine: 3.6L
It's no crime to admit you've been beaten by the best...however that being said ...I guess it would deal a severe blow to ones over inflated ego...I mean, that is, if one had such a thing....of course no one here has anything like that ....right? Ha Ha
Engine: 3.6L
You guys wouldn't be talking so much trash if you knew what I had up my sleeves........
EDIT: Here, I'll help you, Branden and Rusty out......
vi·car·i·ous ( P ) Pronunciation Key (v-kâr-s, -kr-, v-)
adj.
1) Felt or undergone as if one were taking part in the experience or feelings of another: read about mountain climbing and experienced vicarious thrills.
2) Endured or done by one person substituting for another: vicarious punishment.
3A) Acting or serving in place of someone or something else; substituted.
3B) Committed or entrusted to another, as powers or authority; delegated.
Oops ...I think I struck a nerve.
By the way ...I don't have to live thru anything.... I have had my day and it was far far better than anything you have or will ever have...see below and only dream:
I just enjoy rolling in the dirt wth you guys
Car: White KSwisses
Engine: 5.3L Gen III
I guess color photography hadn't been invented yet........
There we go again.. Not quiet on the 3rdgen front.. Well I was going to include this in my last post, But I figure what the hell..
I don't see reason why James should give up on Jerry so easily.. Vincent harp's on James for the money he has spent.. James gave good information on what he had to say about combo changes .. I'll get mine also.. So deal is.. James get the plans get the weight plan.. You can get in the right direction.. It's for the top.. Can anyone reach it.. I do know this.. By July there is some 3rdgen's coming out.. All Various Ci's And various of intakes.. So Ca.. So as the wrenches turn..
BrandenCali
BrandenCali
Engine: 3.6L
BrandenCali- I don't race, I just talk like I do...or have...awe hell, why don't I just come out and say I've never really raced at a race track
Nice car Don, I've never seen it at the track though. I remember sitting in my dad's lap when I was 5 as he cruised our neighborhood in his '69 Mercury Cyclone with a when I was a kid. I think it was pretty fast. Does that count too?
I haven't spent any more money than Vincent has, He's just had the parts longer. He can talk that all day long but in the end it's just a heads/cam/intake car with a set of headers and a manual trans.
Are you intending this Own qoute of yours.. For myself to admit I never raced at the track? All reality I never fully raced a car in my life.. I enjoy the rush of top end.. However any street racing or drag racing cannot do that for me.. Drag racing probably would make me so nervous Id puke.. I still am interested in making some runs..
Vincent.. I give him credit.. He has been, Well far as I have seen.. The one person most racing at the track.. For several years.. He know's it takes money to build a car..
See everyone at Fontana.. Good Luck.. New subject..
Now James you know can't stand to see that RED 86 Z28 out in front of you at the finishline. I have seen the frustration in your face when you come in 2nd behind me. It's cool. One day I will let you have your moment in the spot light (hell naw, I don't think so!). And you will have a big smile on your face.
Engine: 3.6L
Car: 1990 RS
Engine: LO3 TPI
Transmission: W/C T5
C’mon homie, toss me the keys so I can show you what a real 12 second pass looks like.
Engine: 3.6L
Now Mike before you can talk any kind of mess get your own car with your name on the title, do some mods bring it to the track, break in the 12's and then talk some mess. Mean while this is not your fight. The man thinks he himself can beat me anytime he wants and that will not be the case. Let Jr. drive his own car to get his own bragging rights. You know, make a name for himself in the streets and at the track. James needs to let people know who James is and to have second thoughts about racing him. Right now no one is scared to race James. Since he built this I guess maybe I don't know but I doubt it 11 second ride, he should go straight to the top to have bragging rights. If he can't do it then I'll be the next one in line to take him on and thats a fact and I will stand by it.
So now go for the TOP DOG and don't make any mistakes otherwise that's yo ***! Randy and I will be looking for your ***!
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
Some of you might be interested to know, Don has fixed the vacuum leak. He also found a clogged fuel filter and put in a stock chip. What a difference!
I feel like a kid with new roller skates. When will it stop raining?
I was running a totally useless aftermarket chip (it came with the car when I bought it 3 years ago.) Among other things it had bypassed the EGR completely. No wonder I failed smog in '03.
The car should be like 13.00 next race!
I have no other plans for the upcoming year except winning the lottery and replacing Jerry as the #1 fastest driver.
I feel like a kid with new roller skates. When will it stop raining? I was running a totally useless aftermarket chip (it came with the car when I bought it 3 years ago.) Among other things it had bypassed the EGR completely. No wonder I failed smog in '03.
Car: White KSwisses
The car should be under 14.00 next race.
I have no other plans for the upcoming year except finishing school.
That post was completely inappropriate. There was no smack talking of any kind
And I expected more from you...
