Southern California Area Southern California Members.
wtb some stuff around la
Old Sep 11, 2005 | 09:15 PM
android's Avatar
Car: 1989 Iroc
Engine: 5.7 350 TPI
Transmission: 700r-4
Hello guys I wanted to buy some stuff for my camaro near los angeles here is a list...
(Any Performance Parts)
1.Black out Tailight Covers
2.Shift kit
3.Headers
4.Super 40s Flowmasters
5.Hypertech Chip
6.Random Engine Aluminum Stuff
Thats it for now thanks!
Oh and a custom camaro speaker box or kickpanels!
Old Sep 11, 2005 | 09:56 PM
Russ-So Cal's Avatar
Youy need to give us details about your car. If it is a third gen don't waste your money on a hyperchip.
Old Sep 11, 2005 | 10:42 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Re: wtb some stuff around la
Originally posted by android
2.Shift kit
PM me...I got a good one and am willing to deal
Old Sep 12, 2005 | 02:30 AM
android's Avatar
Car: 1989 Iroc
Engine: 5.7 350 TPI
Its a 1989 IROC-Z all stock
Old Sep 12, 2005 | 06:52 AM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Transmission: W/C T5
4. Super 40s Flowmasters
PM me The deal of the century is waiting for you...
Old Sep 12, 2005 | 01:59 PM
Dyno Don makes the best set of headers for the v8 third gens. Another set that is great for the street are the Hooker 2055's, both of these give excellent spark plug access and are made to allow you to keep the plug wires from burning on the headers. Don's headers are a modification on the SLP design that allows for clearance with the steering column without having to bash in a header tube. Your best bet for a custom chip is to contact Dyno Don or his son Kevin. They don't just burn a generic chip like the over the counter aftermarket chips. They will hook up a computer to your car and as you test drive it they will customise the chip settings to fit exactly what your engine is doing under all conditions. You would have to check with them on price, but it will be competitive with the aftermarket generics.
Old Sep 12, 2005 | 02:25 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Old Sep 13, 2005 | 06:10 PM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Originally posted by 1989GTATransAm
Old Sep 14, 2005 | 11:35 AM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Here you go...
Old Sep 15, 2005 | 01:10 AM
android's Avatar
Car: 1989 Iroc
Engine: 5.7 350 TPI
if anyone can help me out I would appreciate it. The mufflers look to beat up Im looking for sometthing more new. I also wanted to know what the MAF sensor does for the car. Does it control the airflow to the engine? Is there anyway to let it breathe more? Tell me what upgrades I should get for my car. I really wanna be able to beat a 4th gen SS camaro with a passion.
Old Sep 15, 2005 | 10:19 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
a 4thgen SS ... ok would that be the 96-97 LT1 or the 98-02 LS1?
and i would highly suggest using the search button before you just start buying parts..
Hypertech is crap.. Talk to Dyno Don or Kevin on this board.. they are really really good at what they do, and will give you advice on what you need.
places to start modding a stock car.. would be a full exhaust.. then a cold air intake/filters, computer tuning.. ect.
the one mike just pictured above is not beat up.. its just weathered a little bit, which a new one will look like in about a month or 2...
so you want to beat it in a 1/4 mile? or road race? or 1/8mile or what? i hope you dont street race..
Old Sep 15, 2005 | 11:53 AM
I don't race, I just built my car for cruising, but I've hung around Don's shop enough helping him with cars and talking about combinations enough to get an idea what works for drag racing.
You want a 3.42 posi rear end, with a t-56 3.73 is even better, but it is probably a little low for a daily driver with an automatic or t-5.
For rear suspension, don't bother with any high dollar upgrades unless you just want to spend money. Don can box your lower control arms, and fab up relocation brackets, as well as box your panhard rod as well.
For an engine combination, the 23 degree Trick Flow heads on with a 10.5:1 c.r. makes great power at a reasonable cost. There are a number of cam choices depending on trans, and how much low end you need, and whether you are running a stock converter or loose converter. A set of Don's headers, the dual cat set up with a 3 inch cat back through a free flowing muffler like Flowmaster, Magna Flow, etc. For an intake, some guys are running Super Rams, Allen, Don, and Kevin are running a large base, big runners, and a ported stock plenum. If you get siamesed runners like Edelbrock, SLP, or TPIS, you can remove part of the dividing wall between the runners at the top and bottom to make the runners part of the plenum which raises the peak rpm. Allen's dyno numbers showed massive hp and torque gains throughout the rev range. You can get 330-350 hp at the rear wheels with this sort of combo. That gives you Lt1/Ls1 hpower numbers.
Old Sep 15, 2005 | 01:22 PM
android's Avatar
Car: 1989 Iroc
Engine: 5.7 350 TPI
thanks guys...It would be a 2001 LS1 SS. I dont street race because they will total my car if I get caught. Does anyone know the number for Dyno Don I tried Pming him but no answer. And what do you guys think about the Exhaust system pictured above? Should I get it?
Old Sep 15, 2005 | 02:24 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
Don's # is 714-633-5168.. his machine will pick up after 2 rings.. just leave him a message... he is usually working on a car or 2.. so he might pick up as you are talking..
the system above should be a 3" system, and is waaaay better than stock.. i believe that the muffler should be an 80 series.. which is a pretty decent sound and flow.. i have the same on mine at the moment.
when you do the headers, dont forget to buy a 3" cat as well. Magnaflow has a line of cats by Carsound, and usually you can find them on line for around 60$
and to beat an LS1, with a driver that is at lease decent.. you're going to be getting into a cam/head/intake swap..
best thing is do to your research on this board, talk to Don or any other members with good combo's. Get your budget set on how much you want to spend, total.. include extra for little parts that you dont always know about.. then set out to get what parts work well with each other..
Old Sep 15, 2005 | 02:56 PM
cali92RS's Avatar
Car: White KSwisses
I must disagree with what people are saying in this thread....
What you need is a SHIFT KIT...and I just happen to have one
Deal of the MFin millenium.
Old Sep 15, 2005 | 03:11 PM
V6#20's Avatar
With the ratio's I've seen on the t56, I would not go with anything other than 4.10's.
The ratio's I've seen-
1st:2.66
2nd:1.78
3rd:1.30
4th:1.00
5th:0.74
6th:0.50
Would give you a cruise speed of 75mph @2000rpms with 4.10's. Anything taller would render your 6th gear useless.
Old Sep 15, 2005 | 04:03 PM
I had forgotten that 4:10's were available. Now that you mention it, I remember Don telling me that Jerry found a set of 4:10 to fit the 9 bolt if I remember correctly.
Old Sep 15, 2005 | 04:46 PM
android's Avatar
Car: 1989 Iroc
Engine: 5.7 350 TPI
what kind of shift kit and how much? What stages is it and so on. And the guys on the thread have to agree and whether to buy it or not.
Old Sep 15, 2005 | 05:11 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
1st:2.66
2nd:1.78
3rd:1.30
4th:1.00
5th:0.74
6th:0.50
are you talking for drag racing? or road racing Dean? those ratios you list are from the 94-97 T56.. the one im using, as well as Don, is set up like a 93 T56,
1st: 2.97
2nd 2.07
3rd 1.43
4th 1.00
5th .80
6th .62
i still have my crappy 3:23 rear.. but i am going to a 3:42..
Old Sep 15, 2005 | 05:18 PM
cali92RS's Avatar
Car: White KSwisses
Why do you need their input on what to buy? its your money.
Transgo shift Kit
http://www.700r4l60e.com/store/custo...&cat=28&page=1
Im selling it for $100.
Old Sep 15, 2005 | 05:22 PM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
I think your shift kit combined with my exhaust system would make for an incredibly pleasurable experience behind the wheel of this young mans third gen.
Old Sep 15, 2005 | 05:37 PM
cali92RS's Avatar
Car: White KSwisses
I concur....
Old Sep 15, 2005 | 05:43 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
you guys are funny... talk about sales men
BUT i probably have to agree.. it would make the ride a bit more fun to drive..
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
anesthes
Sep 30, 2015 07:48 AM
