Southern California Area Southern California Members.
Need Injector Help
Old Jan 7, 2006 | 04:49 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Need Injector Help
I need new injectors what brand and size is everyone running Ford, Accel, Venom 24# or 30#
Old Jan 7, 2006 | 08:29 PM
BrandenCali's Avatar
Im running Ford Svt 30lb Like them no fuel shut off.. Nice pressure.. When I get the fuel system done pressure should be even better.. Some may not like my extreme ideas but I got's to do what I think best fits me..
Old Jan 7, 2006 | 08:49 PM
Russ-So Cal's Avatar
Re: Need Injector Help
It doesn't matter what everyone is running. You need the correct size injectors for your car. If it is a stock L98, you need 22# injectors. If it is modded, you need to tell us in detail every mod that would have an affect on fuel needs before anyone could begin to give accurate advice.
Old Jan 8, 2006 | 02:29 PM
ron reece's Avatar
Car: 92 B4C/1LE CHP camaro 06 vette LS2,
Transmission: iroc, 700r4, auto
i've got accel 24#ers in my 383, seem ok.
Old Jan 8, 2006 | 03:22 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
Thanks for the input I'm going 30# but don't know what brand.
Old Jan 8, 2006 | 03:27 PM
Well then I guess you know the answer to your question already if your set on 30.. Now just what brand.. You understand the diffrence in the Ford Injectors?
Old Jan 9, 2006 | 01:26 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
Branden what difference would that be in the Ford Injectors GM uses bigger O-rings.
Old Jan 9, 2006 | 02:40 PM
Im not sure what the difference is, maybe the spray pattern.. Some mention the 30lb fords having a 4 pin hole.. 14 ohms and Hi resistance.. I don't know everything about them.. But what I have learned is the no fuel shut off, may be a better injector for Higher duty cycle.. You can run them as a smaller injector in the ecu I believe.. And they work well.. You can run more fuel pressure obtaining the better spray pattern..
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
