Built 700 built weeks away
The Red Roc is going to be rolling here real soon.. The trans is going to be tougher than you think
I finished off ordering my Trans Go Kit's.. "Gotta Go Trans Go" Danny's famous words.. I picked up that Beast Sun shell, a transgo sep. plate.. And thats about it.. Not much else needed.. So now my only thought is my converter.. Am I going to trust that with my X $$$ transmission.. It's a 2800 stall Toys converter, Could they rebuild it or restall it what ever it is they do?
I finished off ordering my Trans Go Kit's.. "Gotta Go Trans Go" Danny's famous words.. I picked up that Beast Sun shell, a transgo sep. plate.. And thats about it.. Not much else needed.. So now my only thought is my converter.. Am I going to trust that with my X $$$ transmission.. It's a 2800 stall Toys converter, Could they rebuild it or restall it what ever it is they do? Re: Built 700 built weeks away
5 pinion front planet
Heat treated input shaft
Steel Sleeve the input drum
Cryoed foreward piston
5 pinion rear planet
Steel pump rings
29 element sprag
Re: Re: Built 700 built weeks away
Originally posted by JERRYWHO
What about
Steel pump rings
29 element sprag
What about
Steel pump rings
29 element sprag
A heat treated inputshaft is Idea.. But I don't want to put that kinda money into a trans that is well known to fail somewhere along the road.. However They have a heat treated drum with Larger Clutches.. That can be interesting for a 4l60e..
I did get a Borg Warner 29 element along with a 13 vane pump with hardened pump rings.. And thrust bearings etc.. Im unsure still if the 13 vane was a bad idea..
What is the Cryoed fwd piston?
Brandon, Go with the GM '02 OEM rear 5 planetary gear setups and fronts for that matter. They are stronger than any aftermarket ones currently being made. I have been running them in my current truck tranny for a few years now and they are extremely trouble free. Trust me, I have wasted many 700r4's in this truck since I bought it new in '89. I probably had at least 6 or 7 trannies in this truck including the previuos one Jimmy built me (Darrell Youngs Racing Trans) that was a 4 planetary setup. We replaced that broken one with new GM parts- (still 4 plantaries in it) but all the bells and whistles were transfered to a V6 case and I put that one into the Camaro about 3 1/2 years ago. Its fine for the low HP V6, but my truck still wasted it. The latest one in the truck has all the aftermarket extreme performance internals- spared no expense. The 5 planetaries are well worth the money in the longrun and especially for daily abuse and heavy loads I haul around.
PS- Jimmy even blocked the accumulator pump in this unit to aid pressure I guess for the 1st gear hold- I think if I recall. Damn trannies are like a foriegn language. I watched him build it but I can't remember all the intricacies of the internals and his modifications and tricks.
Yeah I wish I could but my spending limit is up on this transmission.. I could have went some other routes in the build and cut some cost but I couldn't.. My plan is just to baby the car and get things running good.. I want the car together and running when drag racing starts.. I may even consider not doing my fuel system plan.. It's just I don't have all the total facts of the outcome of the system for all conditions.. James is kinda right.. What's the sense? A good intake pump is good enough for our performance levels.. But there is the concern of the sock problem.. That's one problem with the last pump..
Well, before we started we ran into a problem with the Pump.. The pump rings or vanes Scored? into the pump.. So Ivan is checking out if that can be fixed, machined etc.. It's the Flat side of the pump not the side the pump stuff sits into.. It's not real deep but it is a lil.. So that is going to put us back a few weeks.. I have to Make a trip to Vegas for a Tournament.. And Ivan is real busy himself with his projects.. So we can still keep our Fontana Goal with this new transmission with the set back..
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Hey buddy,
I have to stop tomorrow at the school to use the resurfcing machine to fix the pump. Also please return the 13 vanes kit because everybody I know told me to stay with 10 vanes; on the other hand, it takes couples of hours to modify the pump for the 13 vanes.
Originally posted by Dyno Don
Turn it in for a rebuilt one ...exchange
That is so Smooth..
Im going to see about picking up a brand new 10 vane today if I can get a chance.. Im still considering going an checking out those parts we were talking about yesterday..
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Originally posted by james_85Z28
Built 700 built weeks away = Re-built 700 weeks more away
; it means building a bullet proof 700R4 is weeks away
LOL
LOL
I think it will be one of the better transmission's I have ever owned or had built.. Were not making this trans shift all hard either.. I can't handle that no more.. Shift's will be nice and clean and crisp.. lightly chirp the 2nd and have a nice firm 4th..
Im just looking to get those Dam passes.. April whenever.. So hopefully a Few Red cars will be ready to set some action.. We have a handful.. It be great to see all of them..
Buggy Disaster
Sep 22, 2015 01:15 PM
84 TA NV
Sep 6, 2015 08:02 PM
