Southern California Area Southern California Members.
Test only smog
Old Jun 12, 2006 | 05:12 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
Test only smog
Hey, I'm looking for an "easy-going" well-mannered smog tech here in southern california. I know Don knows one, but I havent been able to find a name or address yet. I think it would have to be test only, althoug the car is registered in a basic smog area, so maybe it wouldnt. My smog equipment is all intact and functional, but there's a little problem in the form of 8 smoothly bent tubes. Any help would be great, thanks!
Old Jun 12, 2006 | 05:46 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Can you explain that a little more (the 8 smooth pipes)?
Old Jun 12, 2006 | 06:56 PM
Naft's Avatar
headers
Old Jun 13, 2006 | 12:00 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Why didn't you just get headers with an E.O. number? They're very abundant for V8 3rd gens.
BTW: No matter where you go, since you're in a basic area, you'll just get the standard Two-Speed Idle Test, no Dyno for you my friend.
Old Jun 13, 2006 | 01:19 AM
Naft's Avatar
i didnt put them on, i think don did . . . I've got Jeremy's RS that was Don's rs maybe? lol.
if not when i go back up north in a few weeks i can find a guy up there who will do it, it would just be nice to know someone down here.
Old Jun 13, 2006 | 01:32 AM
DRR's Avatar
DRR
Car: Nothing stock- I screw with everyth
Engine: Hook&Ladder #8
Transmission: Morris Code
Axle/Gears: AxleROse CD Collection & Scuba Gear
Naft, I can't help you. My connection retired 6 months ago. Things seem tight right now. you can always go the route of posting on the exhaust board for someone in a smog exempt state to sell you a legal EO tag popped off a legal aftermarket set of headers for your application (as long as they are shorties you have right now)
Vsixtoy
Old Jun 13, 2006 | 09:43 AM
Dyno Don's Avatar
Hey...it's no big deal, if the one you go to won't smog it, go see a different one.
Old Jun 13, 2006 | 10:55 AM
Guest
Guest
Posts: n/a
Just dont let them run a test and fail you for visual (headers) or you will be replacing them.
Old Jun 13, 2006 | 11:09 AM
Russ-So Cal's Avatar
It seems there are two types of smog techs. The ones who look for the correct smog equipment and don't worry about CARB EO# if the air tubes and egr is hooked up. Then there are the ones who will try to fail you on visual if it isn't stock and they just don't care about CARB EO#. There may be some out there who see headers and want to see a CARB EO#, but I've never heard of one.
Old Jun 13, 2006 | 12:45 PM
Naft's Avatar
that what i got. he knew everything was complete and working, but just wanted the #. which i guess is the letter of the law, so i can understand that.
oh well, I'll just hunt around when i get back north, right now im in the middle of finals and dont have the time to cruise around trying to get it smogged, and i have plenty of time to wait. the funny thing is from the way the guy put it he didnt even care if the headers were legal or anything, and that if i had just quoted an EO number for any set of 3rd gen headers(without any proof whatsoever) he wouldnt have given a rat's *** if it were for those headers or not.
thanks anyways guys, and if it comes down to it ill go for what dean suggests. dont think it will come to that though.
Old Jun 13, 2006 | 12:50 PM
DRR's Avatar
DRR
Every station I have ever gone to I must always be getting the guy with a hard-on for the rules.
I always get hammered for my Thorley headers on my truck. They are an original tri-y set that Doug made years ago before he stated tacking on the EO tag to the headers. I have the EO sticker and they still give me a hard way to go everytime.
The last guys even hammered me for the Holley TB that looks pretty much like the factory unit but chrome. There is no EO for that but I keep the original box label showing it is a type 1 smog compliant part and does not need an EO.
Old Jun 13, 2006 | 01:33 PM
Dyno Don's Avatar
Give me a call and I will hook you up. (my # is up top)
Old Jun 13, 2006 | 03:37 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
I always look for E.O. Numbers on things that are non-stock and require them. If it's not on the car, then I ask the customer, then I double check the E.O. number on the BAR website. I don't have the money to pay for fines and since this is my job, it's what I signed up for, I'm not going to risk losing my license because someone else that I don't know doesn't want to follow the rules.
Old Jun 13, 2006 | 03:58 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Now I know where not to go.
Old Jun 14, 2006 | 12:42 AM
Naft's Avatar
Thats what I expect from pretty much anyone. But, would [you] be able to tell the difference between edelbrock headers and some other set of shorties with AIR/EGR? does a picture come up on the BAR website? I wouldnt go to the trouble of getting the actual plate from a legit set, but if I were to have the number written down somewhere would that probably pass?
Don thanks a lot for the help. I think Im gonna hold off until I go back north(calculus and chemistry finals, bleh), but if when I come back down in august I still need a smog I'll give you a call.
Old Jun 14, 2006 | 09:55 AM
I don't know if he could tell who made just any set of headers you had on your car, but there is nothing anywhere that looks like Edelbrocks except Edelbrocks, and you can always spot the Edelbrocks by the burned plug wires that go with them.
Old Jun 14, 2006 | 08:48 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Just tell the smog guy they're a set of SLP 1 3/4", because that is (basically) what they are.
NZKnight
Oct 15, 2015 02:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
raymondandretti
Sep 27, 2015 06:43 PM
wstephan96
Sep 25, 2015 04:28 PM
reactor60
Sep 22, 2015 01:44 PM
