Southern California Area Southern California Members.
TPI vacuum help
Old May 2, 2007 | 08:33 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
TPI vacuum help
There are two vacuum lines coming off the vacuum can behind the passenger headlight. One of them is larger and goes to the throttle body. One is smaller and branches into a "V". One side of the "v" goes to a plastic fitting underneath the throttle body. I cannot figure out where the other one is supposed to go? I replaced all the vacuum lines when I did my top end gaskets and can't find the home for this one.
It an 87 TPI 305, thanks!
Dave
Old May 2, 2007 | 12:07 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: TPI vacuum help
On my car the port under the throttle body feeds the egr system.
Here is what my car does with the charcoal canister. The big one goes to the gas tank meeting a pipe by the frame on the passenger side. The smaller one on top goes to the throttle body as you described. The one by itself vents into the fender well. Hope this helps.
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 17, 2015 02:00 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
