Southern California Area Southern California Members.
Re: Quick Cali Smog question...
Old Aug 7, 2007 | 11:19 PM
Outlaw28's Avatar
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
im moving down to souther cali in a few days...car i bought had the motor changed but all the stock stuff put back on...its no longer a 305 its a 350 but with all the stock smog stuff and etc etc...should i have any problems passing with a different motor...and what do i need to do if not...and what is a EO number u keep talking about...i live in washington state and we have no smog or any tests what so ever inless u live in the city area like seattle...it looks stock has cat...it is a 4bbl car came 4bbl...only thing that i know of has been changed is motor...and the distributer has been upgraded to hei...
Old Aug 7, 2007 | 11:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The EO number means Executive Order Number, and it means the part has passed CA's emissions testing program and is now legal to install on a street vehicle in CA, or other states that are using CA's smog check program. They give it a number so it can be tracked in the computer.
As long as everything the car came with is hooked up, such as the EGR, canister, AIR pump and lines, catalytic converter, air filter housing, etc, you will pass no problem. 350's put out only a tiny bit more emissions than a 305. Just dont tell the tech you have swapped the engine; tell him its a 305.
Old Aug 8, 2007 | 12:42 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Kevin is right on the money, I'd recommend to say nothing, and he won't ask, he'll assume it's the original engine and if all your smog equipment is in place and working, it should pass. If the Cat converter is original, get some "pass or don't pay" additive in an auto parts store, just for insurance.
CARB EO numbers are for aftermarket parts (headers, intakes, etc) to be legally used on CA smogged cars. If it is a stock original part for the car, no EO number is required.
Good luck
TA
Old Aug 8, 2007 | 02:52 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Just hope he doesnt read the number on the back left of the block. or cant change liters to cubic inches.
jaridjohn
Oct 5, 2015 07:01 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
