Southern California Area Southern California Members.
hey was up Socal
Old Aug 24, 2007 | 08:05 PM
cleanz_28's Avatar
Car: 1987 Chevrolet Camaro
Engine: Vtec Killer
Transmission: the kind that loses Hondas in 1st.
Axle/Gears: the kind that turn the wheels
hey was up Socal
So Ive had my Iroc for about two years,im on z28.com and I finaly found this site.Its great.well Right now im trying to track down a replacement engine for it.Does anyone know where I can find engines is Socal ?
Old Aug 25, 2007 | 01:38 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: hey was up Socal
Depending on how much money you want to spend, go with a GM crate engine.
Old Aug 25, 2007 | 02:59 PM
cleanz_28's Avatar
Engine: Vtec Killer
well I wanna spend nothing more than 900 right now.How much is a Gm Crate?
Old Aug 25, 2007 | 06:58 PM
Guest
Guest
Posts: n/a
A lot more than 900.00 A zz4 crate engine 2,289.00 And that's just a short block.Want to build your own engine? Build it to your satisfaction using the durable, dependable ZZ4 short block. The 4 bolt main block is stuffed with a forged steel crankshaft, flat top pistons and PM rods. Cam, lifters, timing set and oil pump are not included.
So a Crate engine is out of the question with 900.00. You might be able to find a used L98 but that's a used 350ci.
Best bet is save your Right now money.
Good Luck
Old Aug 26, 2007 | 04:27 AM
cleanz_28's Avatar
Engine: Vtec Killer
i can get a lt1 with a tranny for 1200...Blah,Im gonna go buy a tohoe.And then save up for the Iroc.
Old Sep 30, 2007 | 03:07 PM
VETTEpwrdZ28's Avatar
Car: 75 SHORTBED
Axle/Gears: stock
z28.com
Loudnproud86
Jul 14, 2016 12:59 AM
DiabloWS6
Feb 15, 2016 02:08 AM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Keiffer76
Sep 9, 2015 08:52 PM
89 formula TPI
Sep 8, 2015 08:00 PM
