Southern California Area Southern California Members.
Smog pump!
Old Oct 30, 2007 | 10:23 AM
black_highway's Avatar
Car: 91' RS Camaro
Engine: 305c.d. Toilet Bowl Injection
Smog pump!
For the past few das my motor had been running weird, it just sounded different to me. I took the belt off last night and spun all the accessories, and the smog pump is really grinding away at itself. Now, seeing as I don't want to be sent to the smog gulag, how do I fix this before it seizes up on me?
Old Oct 30, 2007 | 11:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Smog pump!
More than likely you will need to replace it, but a temporary fix would be to remove it, oil the bearings, and replace it. You can also try squirting the oil in thru the back hole after removing the black pipe that leads to the black plastic air diverter assembly.
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
