Southern California Area Southern California Members.
Fan Question
Old Jan 10, 2008 | 07:08 PM
SPIKESU's Avatar
Car: 1989 RS CAMARO
Engine: 305 TBI
Transmission: AUTO
Fan Question
Where do I start.....ok one afternoon I turned on my car and my friend and I noticed the car was over heating.....? Well we noticed that the fan wasn't turning on.
Steps:
1. Replaced the fan (Nothing)
2. Replaced the relay switch (Nothing)
Can someone please help me understand what my problem might be??
Old Jan 10, 2008 | 07:22 PM
Russ-So Cal's Avatar
Re: Fan Question
How hot is "overheating"?
Steps:
Did you replace the relay or the fan switch? There is a relay that turns on your fan, but it is controlled by a thermostat switch on the engine. That switch is separate from your water temp ga. sender. That also brings up the question, did you check to make sure your temp was as hot as the gauge indicated? One more thing I just thought of, does your car have ac? If it does, did you try turning on your a/c to see if the fan comes on then?
Old Jan 10, 2008 | 10:04 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Fan Question
On the right side head, there is a temp switch, (it's between 6-8) remove the wire and gnd. it with the key on. It should make the fan run, if it does, replace the temp sw., if not then you will need to start tracing the wires to see where the problem lies.
Old Jan 10, 2008 | 11:14 PM
SPIKESU's Avatar
Car: 1989 RS CAMARO
Engine: 305 TBI
Transmission: AUTO
Re: Fan Question
I'll try that...thanks on the lead .
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
