Southern California Area Southern California Members.
Backspacing
Old Jan 19, 2008 | 02:12 PM
92Birdofprey's Avatar
Car: 92 Firebird
Engine: 3.1
Axle/Gears: stock, dynomax turbo exhaust
Backspacing
I ordered some rims from Summit and realized that it would not fit my car, I cancelled it, now I'm going after new wheels. I know that the backspacing of our cars is 3 and 3/4's, the wheels that I want to buy are Mickey Thompson's but have a 3 and 5/16's backspace, do any one of you know if (3 5/16's) wheels will fit our (3 3/4's) cars? Thank You so much.
Old Jan 20, 2008 | 01:07 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Backspacing
Check here:
http://www.skulte.com/adapterfaq.html
7/16" should not be that big a deal.
Old Jan 20, 2008 | 10:56 PM
Gr89RS's Avatar
Car: '02 Z06
Re: Backspacing
You can go up to 6" backspacing on these cars without a problem, 5.5"-5.75" if your car is really lowered.
Obviously tire choice can effect this but for the most part ^
Old Jan 21, 2008 | 07:24 AM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
Transmission: TH700R4
Re: Backspacing
Is the back spacing the same front and rear? I was under the impression it was different? Stock rear was 5.5" and front was less?
Old Jan 22, 2008 | 12:44 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: Backspacing
Front should be 4.5" for the front 16x8 wheels. 5.5" sounds about right for the rear. Might be closer to 5.25".
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
