Southern California Area Southern California Members.
HELP CANT FIX CAR
Old Feb 14, 2008 | 02:38 PM
jessc50's Avatar
Car: 88 supercharge Iroc Z,
HELP CANT FIX CAR
I been trying to fix my car for a while now but cant seem to figure out was wrong change a few things but same problem so i was wondering of one of you guys could come down and help me or atleast tell me whats wrong wit it ill pick you up and pay you for your time now that i got my taxes and gonna have extra money
Symptoms of car turns on idles really ruuf then turns off has really no throttle response but if u hold down gas it will not turn off
things i change spark plugs, spark plug wires, iac valve was told that it might be the maf sensor but couldnt find a way to check it and dont want to go buy one then find out that that wasnt the problem
so if anybody could help me i wil apreciate it miss driving my car thanks
Old Feb 14, 2008 | 02:59 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: HELP CANT FIX CAR
First question — is the "check engine" light on at all?
If it is, then the computer will have a Trouble Code stored. That code will tell where to start looking, rather than throwing money at it.
MAF problem will turn on the light and set a code.
From your brief description it sounds like you have a vacuum leak some where. Check for any cracked or broken rubber lines on the intake manifold and the Evap. Canister.
Old Feb 14, 2008 | 03:06 PM
jessc50's Avatar
well when i jump it it gives me no codes but i did have my battery diconected cus it died so they might have cleared ill check for cracks and broken lines see if i see anything O and i also changed fuel filter and check fuel pressure and it was fine
Old Feb 14, 2008 | 06:10 PM
Pyroviking's Avatar
Have you checked to see if there's any exhaust coming out of your tail pipe? The catalytic converter on my '85 T/A got clogged up (back in '90) and the symptoms you describe are almost identical.
Old Feb 14, 2008 | 07:34 PM
jessc50's Avatar
took a look at the hoses didnt see any crakked or broken hoses but gonna double chek that because i could have easily missed something and i did get exhaust from the tail pipe what else could it be
Old Feb 15, 2008 | 12:04 AM
drewdown84's Avatar
Car: 1987 Camaro IROC
Engine: V8 5.0L TPI
Axle/Gears: 10 Bolt
you said you did plugs and wires... are you 100% sure you got all the cylinders right?
Old Feb 15, 2008 | 12:14 AM
jessc50's Avatar
yea im sure i did the plugs and wires right it was doin exact same thing before i changed them too just that i found couple wire were burn so i thought that was causing the problem
Old Feb 15, 2008 | 01:29 PM
IrocZonNos's Avatar
Car: 1988 IROC CONVERTIBLE
Engine: 305 TPI PAXTON SUPERCHARGER & NOS
What supercharger do you have?
Old Feb 15, 2008 | 06:33 PM
jessc50's Avatar
vortech
Old Feb 18, 2008 | 02:15 AM
trent89iroc-z's Avatar
hey i had the same thing happen to my car of its a tpi make sure your intake tube is on there good
Old Feb 18, 2008 | 11:34 PM
jessc50's Avatar
yea is a tpi 5.7 the intake tube is on there good cant figure it out ima record a video and see if i could post it so u guys could get a beeter idea cus im tired of seeing sitting there wanna drive it already
Old Feb 19, 2008 | 06:54 PM
iroc u 05's Avatar
Car: 89 iroc t-tops
Engine: 305 tpi stick
i had the same problem u have and it was the maf sensor i still have the problem but i also didnt want to throw my money away not knowing what was really wrong with it. so an easy way to check your sensor is by disconecting the plug and if your car stays on then its your sensor thats the problem. your close by so if u want to see my car how it acts when i hook up the sensor private message me with you number. hope i helped.
Old Feb 19, 2008 | 07:41 PM
jessc50's Avatar
ok thanks ill see wat my car does with the maf sensor unplugged then illlet u know
Old Feb 20, 2008 | 04:20 PM
Car: Yes...
It should turn on the SES light and set a code 33 when you unplug it.
Old Feb 20, 2008 | 08:41 PM
Russ-So Cal's Avatar
Have you run the car in the dark with the hood up to see if you have any ignition problems? It may seem silly to ask, but since you didn't mention what exhaust headers you have, could you have accidently fried some of your new wires on a header? Did you use silicone grease on the boots when you put the wires onto the plugs? Did it possibly create a seal that pushed the boot right back off when you installed the new plug wires?
Old Feb 21, 2008 | 02:40 PM
jessc50's Avatar
ok discconected maf and car didnt turn off anymore so i guess it was the maf causing the problem ses light did turn on but once i get new it should go away right? Also i was getting some sort of popping sound not sure what it was u think the maf being discconected caused it or maybe because i messed with tps guess i have to adjust it
russ i have stock headers ill check for any ignition problems too maybe that could cause the popping sound also because i dont remember using grease on boots i did use the grease on sparkplug tread so they wont get stuck but not on boots
hopefully that was it for my problems
Old Feb 21, 2008 | 03:23 PM
Car: Yes...
Did it ever set the SES light before you unplugged it? MAF trouble, be it the sensor itself or the relays, typically trigger the SES light and trouble codes of either 33 (MAF Sensor), 34 (MAF Power Relay) or 36 (MAF Burn-off Relay).
A new MAF Sensor is not a cheap part, so I'd hate to see you drop money on it only to find out that's not the problem. The relays are only around $10 each.
MAF Sensors are usually parts you can't return either. Once you plug it in, you own it.
Old Feb 21, 2008 | 03:51 PM
jessc50's Avatar
no never had an ses light on so what else could be causing it dont want to waste money if i dont have too
Old Feb 21, 2008 | 04:01 PM
You are not that far from Don in Orange. Why not send him a pm to see if he can squeeze you in?
Old Feb 21, 2008 | 04:04 PM
jessc50's Avatar
yea but car doesnt have plates havent been able to smog it and well im not sure if it will make it dont want to get stranded but im check out how it runs with maf disconnected and ima pm don
Old Mar 1, 2008 | 07:03 PM
jessc50's Avatar
i changed the maf and now car doesnt turn off when maf is connected i tried clearing the codes but i keep geting code 33 which is the maf why do i keep getting this code
Old Mar 4, 2008 | 12:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You turn the key off and the car keeps running? Ok you definitely have some kind of electrical issue now.
Old Mar 4, 2008 | 01:33 PM
jessc50's Avatar
it does turn off with key off i guess i didnt explain myself i meant before car would turn off and idle real bad then i unplugged maf and car wouldnt turn off anymore but i would get code 33 so i got a new maf plugged it in and car stays on now but i still keep getting code 33 eventhoug i put new maf and cleared the codes my ? was why do i keep getting code 33 what else could be wrong
Old Mar 8, 2008 | 01:16 AM
Kevin91Z's Avatar
The guys who are more familiar with MAF cars will have to answer. I'm clueless on this one.
Old Mar 12, 2008 | 12:12 AM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
this maybe a dumb question but is there any holes in the ducts or air getting in past the MAF?
Old Mar 12, 2008 | 12:47 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
i hope this will help https://www.thirdgen.org/forums/atta...lp-code-33.jpg
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
86IROC112
Aug 17, 2015 02:00 PM
Amillionoh7
Aug 7, 2015 01:24 PM
