Southern California Area Southern California Members.
where to take TPI system for porting work
Old Apr 1, 2008 | 01:40 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
I'm looking for a place to port/siamese my friends new TPI parts. He has SLP runners (2nd design) and TPIS big mouth intake. He also needs the Plenum opened up for a 58mm throtlle body. ...... He would like the SLP runners nearly fully siamesed or fully since the car will be supercharged and I don't believe having them fully siamesed will affect the lowend since it's supercharged anyways. Basically he wants it all opened up as much as possible. Since all this will be mounted on a 395 stroker. ....... Any recomendations?
Old Apr 1, 2008 | 10:13 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: where to take TPI system for porting work
Doctor J in Orange California. Dyno Don might have the address and phone number.
Old Apr 1, 2008 | 11:48 AM
thegooseman's Avatar
Car: 1992 RS
You can send it here.
http://corvetteplenum.com/Home.htm
Old Apr 1, 2008 | 12:06 PM
Engine: 4.0 V-6
Originally Posted by thegooseman
Problem there is it seems he only does plenums. I need the whole system punched out. Not worth it sending individual parts to various people rather just have one person do it. But thanks for the link.
Old Apr 1, 2008 | 12:22 PM
Russ-So Cal's Avatar
You can do it yourself with a die grinder at the top and bottom of the runners. The only way to do it all the way through is to cut the runners apart and then weld them back together after the work is done. Jerry did that with the runners he made for Kevin and Don, but decided afterwards that it was just too much work to do any sort of production run. Using the die grinder on the top and bottom of the runners will do as much good as openning them up all the way through. The main thing you are trying to do is move the "tuned length" up the rpm band.
Vintageracer
Jan 10, 2020 05:33 PM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
mx127
Aug 10, 2015 08:13 AM
