Southern California Area Southern California Members.
No help in the general tech/engine section. Maybe you guys can help
Old Jul 22, 2008 | 09:27 PM
thegooseman's Avatar
Car: 1992 RS
Ok this used to happen once in every blue moon and then this past week on my way to Vegas it happened really bad and now wont go away. When I am going about 65-70mph I lose throttle response, as in I push on the gas and nothing happens and then boom. It backfires. Obviously the backfire was me giving it more fuel but why does this happen in the first place? If I went 55mph its ok, so thats how fast I went all the way to Vegas and back home. BTW its about 290 miles. Aslo from a stand still I would rev the engine and this happened with 2000 to 2500 RPM range. Lose throttle response and then backfire. Any help would be great. Thanks
Old Jul 23, 2008 | 10:33 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: No help in the general tech/engine section. Maybe you guys can help
Either your fuel pump is going or the filter is plugged.
Old Jul 23, 2008 | 10:57 AM
Car: 1992 RS
Really? Wouldnt it happen all the time though if it was?
Old Jul 23, 2008 | 12:45 PM
roc-e's Avatar
Have you changed out your spark plug wires? I had something similar happen (not on my IROC, though)--the wires looked okay, but a couple of them were bad. New plug wires fixed the problem.
Old Jul 23, 2008 | 01:11 PM
Car: 1992 RS
Yes I have. When I got the car it was completely stock, and this issue happen probably once when I got it. Then I started doing mods and I got the jegs TPI power tune up kit. I came with a new coil, cap and rotor, and MSD 8.5mm wires. So I didnt think it was that.The fuel pump[ was changed about a year and a half ago and the fuel filter was changed about a week ago.
Old Jul 23, 2008 | 06:58 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
How about the ignition module in the distributor? I know they're usually "runs or not", but they're not hard to swap out (compared to the fuel pump!)
Good luck
TA
Old Jul 23, 2008 | 09:33 PM
Russ-So Cal's Avatar
Don has had to troubleshoot a few ignition modules that did intermittant failures instead of "runs or not."
Old Jul 24, 2008 | 01:48 AM
Car: 1992 RS
Update: Well I drove my car today on the freeway a good 15 miles and it didnt happen. I dont understand why it comes and goes. Hmm by the time I was about 80 miles into vegas are when the symptoms occured. This is all really frustrating
Old Jul 24, 2008 | 11:43 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
On our car cruises during the hotter times of the year some of the cars experienced what I would call "vaper lock". Hard to believe with a fuel injected car but a little bleeding of the fuel lines and all was well.
Old Jul 24, 2008 | 12:11 PM
Car: 1992 RS
Originally Posted by 1989GTATransAm
On our car cruises during the hotter times of the year some of the cars experienced what I would call "vaper lock". Hard to believe with a fuel injected car but a little bleeding of the fuel lines all was well.
Actually when it happens it usually happens on hot days. So how do you bleed the fuel lines?
Old Jul 24, 2008 | 10:32 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Either use a rag wrapped around a small screwdriver to press the schrader valve under the plenum on the passenger side, or crawl under the car and loosen the connection going to the fuel filter.
Old Jul 26, 2008 | 11:59 AM
Car: 1992 RS
Ok something I noticed when my problem was happening was my oil pressure was going down, but never in the red so I didnt think too much of it. Now the average point was always a little over the last line (60) then it would drop down to the second to last line (45). Figuring the sensor was off I replaced it and it now reads about 30 at idle and 45 when accelerating at highway speeds. When I searched about how to replace it I read that it has the ability to shut off the fuel pump. Is this true and do you think this could of been it?
Old Jul 26, 2008 | 01:00 PM
It might, but I've also heard about guys running out of oil and not noticing the oil pressure gauge until the engine failed. In those cases the sensor was perfectly happy to let the engine continue to run until the engine seized!
Old Aug 1, 2008 | 11:41 PM
Car: 1992 RS
Well today on the way down to Huntington Beach my car finially died. The camaro is now at the mechanic and I should have word on the problem tomorrow.
Old Aug 4, 2008 | 12:05 AM
Car: 1992 RS
Apperently it was the ignition control module. Good job Troy. Sooooo do you guys think this was the problem the whole time?
Old Aug 5, 2008 | 02:37 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
could be.. or the real problem may have yet to reveal itself.
might be time to bust out the dvom and test your Throttle Position Sensor as well, what your talking about could be a flat spot in the throttle. kind of a long shot, but i always start there when throttle response is funny.
when i had this same problem... i can't remember what it was. dang.. well that was a big help. oh! it was my MAF.
jklein337
Sep 19, 2018 06:23 PM
ezobens
Aug 19, 2015 10:29 PM
Jake_92RS
Aug 17, 2015 09:42 AM
BurlyChev
Aug 16, 2015 09:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
