Southern California Area Southern California Members.
Emissions Test
Old Oct 25, 2008 | 03:17 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Emissions Test
Took my car in today to the test only center. The only thing different from the configuration that the car is normally run in was that I was burning 87 octane instead of 91 octane. NOTHING else was different. Here's how it went:
%CO2 %O2
RPM Measured Measured
15mph 1778 12.53 2.28 PASS
25mph 1708 12.85 2.25 PASS
HC (PPM)
MAX AVE Measured
15mph 108 31 95 PASS
25mph 83 20 61 PASS
CO(%)
MAX AVE Measured
15mph 0.71 0.10 0.41 PASS
25mph 0.58 0.09 0.30 PASS
NO (PPM)
MAX AVE Measured
15mph 767 237 160 PASS
25mph 706 199 148 PASS
Visual Inspection: PASS
Functional Check PASS
Emission Test PASS
The tech did say that the "manifolds" (headers) should have a CARB EO#, but when I pointed out that the AIR system was intact, he let it go.
An easy PASS with the set-up shown in my sig, making 320+rwhp / 375+rwtq.
Bill
Last edited by Burnout91; Oct 25, 2008 at 04:36 PM. Reason: TABLES WON'T STAY ALIGNED.....I think most will recognize the format.
Old Oct 25, 2008 | 04:06 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Emissions Test
Congrats Bill....
Old Oct 26, 2008 | 10:10 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
Re: Emissions Test
with all those mods, did you get er done with or with out a good tune?
Old Oct 27, 2008 | 08:40 AM
Burnout91's Avatar
Engine: Modded L98
Re: Emissions Test
Tuned by Kevin91Z.
Bill
Old Oct 27, 2008 | 10:50 AM
Russ-So Cal's Avatar
Re: Emissions Test
Congrats. I have to run 91 octane in my T/A to get the nox from going clear off the chart!
Old Oct 27, 2008 | 11:34 AM
Burnout91's Avatar
Engine: Modded L98
Re: Emissions Test
I had read that using 87 octane might help, but now I'm reading that 91 is better....so now I'm not sure if the octane rating is / was a factor or not.
Bill
Old Oct 27, 2008 | 11:35 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Emissions Test
Way to go Bill! Glad to see another one pass CA's smog check. I guess we're doing something right.
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Eric-86sc
Sep 28, 2015 11:37 AM
raymondandretti
Sep 27, 2015 06:43 PM
