Southern California Area Southern California Members.
Smog Fix Question
Old Mar 11, 2009 | 04:25 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Smog Fix Question
Hey all,
Just took a smog test, and failed. What is needed to get the HC and NO down?
Here are the results:
HC CO NO
Max Measure Max Measure Max Measure
15mph 110 150 .71 .46 772 767
25mph 85 90 .59 .07 711 536
The car is a 91 RS with a L98 swap (stock setup) with a Catco cat, and cat-back setup.
What is needed to be changed to lower these numbers?
Old Mar 11, 2009 | 06:30 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Smog Fix Question
You could go with a new cat or have Kevin do a modified custom tune.
Old Mar 11, 2009 | 08:02 PM
Guest
Guest
Posts: n/a
Was the car fully warmed up?
Might just need a tune. What were the o2 readings?
onefreakz
May 14, 2018 12:15 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 7, 2015 09:55 PM
