the 88 is up and running again
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
I smoked my clutch messing around with slicks and finally got around to replacing it. I somehow messed up the counter balance weight between the crank and flywheel and had to pull and stab it one more time. Wow when your engine is out of balance you can really tell.
I also got the opportunity to replace the clutch slave cylinder. Remember to never push in the clutch when the slave cylinder is not installed (or install your flywheel while drinking...hahaha) It was actually one of the easiest fixes I've done.
man that thing is a monster to drive in the city.
I keep saying but can never get the time to get it to Kevin.
I'm looking forward to the BBQ in less then 2 weeks.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
