Southern California Area Southern California Members.
Dyno Day 2 (The Sequel)
Old Sep 11, 2009 | 10:45 AM
  #51
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Re: Dyno Day 2 (The Sequel)
Ok, so showing up to spectate is ok too? I really just interested in talking to all of you guys and picking your brains lol.
Old Sep 11, 2009 | 11:15 AM
  #52
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
OK, trying to figure out a count! We can't do more than 7, six is actually plenty. The cars will go on in the order that you signed up. Please check your timing and fuel pressure (spout connector disconnected to check timing) so we don't waste dyno time doing that. If you need help with that, let us know before the car is on the dyno, and someone will help you. You are welcome to come and watch/spy/learn, and trust me, you will learn.
1. Troy (TA)
2. Lon (lonsal)
3. Burnout91 (Bill)
4. Luis (Godreject)
5. Julie (JulieGTA)
6. Mike (itsMikey)
7. if time allows
TA
Old Sep 11, 2009 | 11:49 AM
  #53
I'll definitely be there to watch and learn then. Look out for a completely black RS.
Old Sep 11, 2009 | 11:50 AM
  #54
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Troy, is not Dyno Don going have his car on the dyno?
Old Sep 11, 2009 | 12:42 PM
  #55
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
I will have to withdrawl my name from the list, my car is not any different then last dyno(besides new exhaust) and i did not do some changes i needed to make, i will attend though and spy, i hope to be ready for the next session though
Old Sep 11, 2009 | 04:05 PM
  #56
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
We'll I am still planning to be there tomorrow so I hope there Is still a spot in for me. My car needs tuning bad..
Old Sep 11, 2009 | 04:37 PM
  #57
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
still planning on coming...me,dad(wicketmike) and my girlfreind..tryin to get her into the thirdgen scene too
Old Sep 11, 2009 | 11:42 PM
  #58
TA's Avatar
TA
Axle/Gears: 9bolt
Everyone is welcome to come and watch. Don did not sign on to test, I don't think his exhaust mods are ready yet, and this looks like a pretty full day already, so we'll definately be going again pretty soon.
1. Troy (TA)
2. Lon (lonsal)
3. Burnout91 (Bill)
4. Julie (JulieGTA)
5. Mike (itsMikey)
6. 90-irocdx3 (Name?)
7. if time allows
TA
Old Sep 12, 2009 | 12:23 AM
  #59
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I was at Don's shop Friday afternoon and he was working feverishly to be ready for Tomorrow.
Old Sep 13, 2009 | 10:22 AM
  #60
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
RESULTS!
OK, let me start with saying that my results were achieved with an HSR intake. MY HSR will soon be equipped with a fully functional EGR system. 'Nuff said.
With some part throttle tuning by Kevin91Z, the base-line run was 382 rwhp / 346rwtq. (I thought we were looking at the wrong runfile...) Kevin added some fuel up top and the second pull was 385rwhp / 37xrwtq, 30 ft. / lb. gain.
Added some fuel up top, took some away down low. 387rwhp / 376rwtq.
It was still a tad lean up top, but Kevin discovered the injectors were maxed-out @ 109% duty cycle. It still had a little more power, if it had more fuel.
These pulls were made on the same dyno that indicated 321rwhp / 377rwtq with an Edelbrock base & modded SLP runners. No changes, other than the intake, were made. Oh, except a little work to open up the airlid outlet, and switching from a Flowmaster muffler to a Magnaflow muffler.
I was blown away.
Thanks to all present (Don, Kevin, Julie, Lon, Troy, Mike, Mikey, Vincent, Allen, Luis, Mark) for the help during the session. Everyone contributed, it was way cool.
Bill
P.S.: Do I have a hangover? Nope, but it wasn't for lack of trying.
Last edited by Burnout91; Sep 13, 2009 at 11:44 AM. Reason: Forgot about the muffler.
Old Sep 13, 2009 | 11:01 AM
  #61
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Old Sep 13, 2009 | 06:18 PM
  #62
Car: 1989 GTA
Engine: 369 TPI
Congratulations Bill to a well built motor. Bill's car has a 700R4 tranny. By the way another example of Dyno Don short tubes headers making good power.
As a side note our Third Gens should make a real good showing at the LA Invitational next year. We should have quite a few low 12 second cars and most likely some in the 11's.
Old Sep 14, 2009 | 01:49 AM
  #63
thegooseman's Avatar
Car: 1992 RS
I just had my car dynoed today. I got 181 hp and 190ft lbs. Now this is on a engine with 176,xxx miles edelbrock baseplate, SLP runners, magnaflow catback, k&n filters with gutted airbox, jegs stage 1 tune up kit, 24lb injectors, with a tune done by my neighbor. My car kept on kicking down to second gear though during the session. Do these numbers sound about right or do you guys think it sould of been better or worse?
Old Sep 14, 2009 | 10:03 AM
  #64
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You need help, that is not good.
A 305 should be about 205 325
Old Sep 14, 2009 | 10:23 AM
  #65
Car: 1992 RS
I guess I need to go to Kevin for the tune.
Old Sep 14, 2009 | 10:53 AM
  #66
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
Way to go Bill, those are some nice numbers.
Old Sep 14, 2009 | 04:33 PM
  #67
itsMikey's Avatar
Engine: 5.7 350 TPI
I was happy with my results =] 250hp 328torque
Old Sep 14, 2009 | 07:51 PM
  #68
Car: 1989 GTA
Engine: 369 TPI
ItsMikey. Not bad numbers at all for your mods.
Old Sep 15, 2009 | 11:58 AM
  #69
itsMikey's Avatar
Engine: 5.7 350 TPI
thanks =]
Old Sep 15, 2009 | 12:00 PM
  #70
Car: 1989 GTA
Engine: 369 TPI
Old Sep 15, 2009 | 12:25 PM
  #71
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Please dont mention rumors and gossip on these message boards.
By the way, how did you car drive on the way home, Mikey?
Old Sep 16, 2009 | 01:20 AM
  #72
Car: 1992 RS
Originally Posted by Burnout91
RESULTS!
I'm interested on how the EGR setup goes. Keep us posted.
Old Sep 16, 2009 | 07:36 AM
  #73
Burnout91's Avatar
Engine: Modded L98
Dyno Don, could you post the graph from my dyno run...having trouble opening those files. What was the barometric pressure?
Oh, nevermind...I just noticed you posted it, along with a comparison to your graph, over in the "TPI" forum.
Bill
Last edited by Burnout91; Sep 16, 2009 at 01:28 PM. Reason: Just noticed thread in "TPI" forum.
Old Sep 16, 2009 | 03:38 PM
  #74
Burnout91's Avatar
Engine: Modded L98
Trusted sources have discovered that the dyno's barometric pressure reference was indeed incorrect on 9/12/09...looks like my rwhp was ~363*. I still like it, love the powerband.
Bill
*More to follow...
Old Sep 16, 2009 | 04:09 PM
  #75
itsMikey's Avatar
Engine: 5.7 350 TPI
well i didnt really get to drive it till sunday cuz my dad made my mom drive it home >:/ but its running great..MPG is up..acceleration is definitly up..and all around it just feels great. THANKS KEVIN
Old Sep 16, 2009 | 05:45 PM
  #76
Dyno Don's Avatar
Bill
*More to follow...
Yes, indeed the machine was set wrong 28.6
Now correct that to what it really was, 30.2 and you do indeed have 380+
Remember, 28.6 is like 2000 ft. we were at sea level (30.2)
The machine was reading 363 uncorrected for that error in baro press.
Old Sep 16, 2009 | 09:42 PM
  #77
Long Beach Z-28's Avatar
Car: 89 IROC Z-28
Engine: 5.7
Transmission: A4
SURE you were at 363 Bill, but that was BEFORE 5000 RPM!!
Congrats Bill, can't wait till ya put some fuel in that animal!
Pat
Old Sep 17, 2009 | 09:47 AM
  #78
Burnout91's Avatar
Engine: Modded L98
I will post a full write-up; may be close to year-end before I have the time for the project.
OK, thanx Don
Pat
Injectors are on the way.
Bill
Old Feb 1, 2010 | 11:55 PM
  #79
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Well, better late than never.
Here's a few videos from Dyno Day 2 Sept 2009.
http://www.youtube.com/view_play_lis...0A0C35C9876C1B
RedLeader289
May 28, 2019 01:47 PM
Mark_ZZ3
May 24, 2018 01:02 PM
jrdturbo
Mar 31, 2016 02:58 PM
darwinprice
17
Oct 11, 2015 11:51 PM
bjpotter
Oct 2, 2015 09:12 AM
