Southern California Area Southern California Members.
strange issue and need help
Old Sep 1, 2009 | 05:31 PM
captain_camaro's Avatar
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
my cousins 87 rs 305
has coolant in the motor oil
but for some reason he has NO OIL in the radiator! (@.@)
im thinking head gasket but still confused....he changed the oil and it had normal oil for like a good while and just last sunday we checked the oil and chocolate milk and also coolant was clean.... is it cursed??
NO OVERHEATING NO NOTHING........ it beat me
PLEASE HELP!!!!!
thanks
Old Sep 2, 2009 | 12:30 PM
Russ-So Cal's Avatar
Re: strange issue and need help
Does he have antifreeze in the cooling system? Let it sit to allow the water to separate from the oil and then drain the water ff the bottom of the sump to see how much you have. If he has antifreeze in the cooling system and any sort of leak between the cooling system and the sump, the water will come out the color of antifreeze. If he has antifreeze in the cooling system, but gets clear water out of the sump, it isn't coolant. Does he pressure wash his engine? If an engine is pressure washed, particularly the left side valve cover, he may be getting water in past the oil fill cap.
Old Sep 2, 2009 | 12:45 PM
Engine: 5.oh tpi
yea he uses peak not dexcool...i told him to let it sit for a few days im going to check it out tomorrow(gota do a speed sensor swap on a cutlas today)im sorry but my english definitions arent mastered yet...what do you mean by check the sump?
(people in my surroundings only speak spanish LOL) his motor looks like he had blown a radiator hose BAD most of his engine looks orange like rusted water BUT OOLD!
ill keep posted
he doesnt pressure wash it as i can tell
but like i said he swapped the oil and a few days later there was the mix again.... do you think maybe a head cyl might be cracked??
Old Sep 2, 2009 | 07:44 PM
You can't tell what it is without a tear down. The sump is another name for the oil pan. Water will separate out of the oil when it sits for a while and if it has antifreeze in it, the anti freeze will color the water. If you drain the water off the bottom of the pan, it will be antifreeze colored if it came from the cooling system. Anyplace that you have water passages and oil passeges separated by a gasket or metal is a potential spot for a leak. Some of those places off the top of my head are the intake manifold gasket (base gasket on tpi), head gasket, cylinder heads, block, there are also water passages in the base of the throttle body on tpi engines. I bypassed mine because they are prone to corrosion, but I'm not sure that water entering the intake would get past the piston. It would probably just go out the exhaust as steam.
Old Sep 3, 2009 | 09:57 AM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
I would say it's probably the intake manifold gaskets leaking coolant internally. Just my
Old Sep 3, 2009 | 11:22 AM
The intake manifold gasket is one place I know of where you will get water in the oil, buit no oil in the water. There is no oil under pressure near the intake manifold, but water leaking past the gaskets will go into the lifter galley and go to the pan around the push rod holes.
Old Sep 3, 2009 | 03:11 PM
bluethunder28's Avatar
Mine leaked from the intake gasket. Seems to be a common problem. I was able to replace mine in one afternoon. Drain the oil, used an engine flush, changed the oil ran it for a while and changed the oil again.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
SG91camaro
Sep 5, 2015 10:27 PM
IROCtometal
Sep 2, 2015 02:01 PM
