Think this intake is worth getting. It does have an EGR.
Car: 1992 RS
Last edited by thegooseman; Feb 1, 2010 at 12:38 AM. Reason: I put a period in the subject line instead of a question mark.
Re: Think this intake is worth getting. It does have an EGR.
No, the ports are very small and no fuel rails that will bolt on. you can see more pictures at https://www.thirdgen.org/forums/alte...-manifold.html
Look at how the stock fuel rails need to be cut up just to fit on it and thats with no fuel cross over tubes or reg.
The epoxy on the outside by the injectors shows how small it is.
Jerry
Jerry
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
JerryWho nailed it, the runners need to be a lot bigger in diameter, it's not going to flow enough air at higher RPMs. If the design was all that great, they would have produced it.
TA
TA
That's the same as the intake I have. Damnit, looks like everyone has found it and is bidding on it. I'm prepared to go a long way to get it, mine has been modified. BTW, the intake is useless without the fuel rails (I have them)
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
It Kinda reminds me of the one that Holly sells.
Tony.
Tony.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Drat it. I'm very interested in bidding on that intake. Looks like the price will be high with everyone knowing about it.
Jerry
Car: 1992 RS
I didnt bother after you pointed out the flaws. But I wonder why their isn't a aftermarket intake like this though? I know there is the Holly Stealth Ram, but its not 50 state legal. The two piece design just looks so much easier to work with. I would of thought BBK would of done something like this and not a super ram copy.
Jerrywho makes it sounds like he knows this stuff better than Jim McFarland, I guess McFarland didn't know squat about manifold design huh?
Also one more intake manifold will be listed soon, the last one.........
Jerry
How did you know that? (I knew it too) Do you know how many of these things exist?
Car: 1989 GTA
Engine: 369 TPI
OK, I'm out of the bidding on these. I will stick with my First intake.
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Jegs has a Wieand Stealth ram for $319.00 or $369 for Vortec heads transfer your stuff over. Better intake anyway.
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
yea 770+ is a grip of money for an intake no one knows much about. I have kept my eye on this item since it first hit ebay....kinda went crazy at the end it looks like
anyone know what this things flows? Would be nice to know what the RPM range is.
You bought it?
Damn, you outbid me then, my max was 757
I was dying to buy it so I have a non molested one.
I was dying to buy it so I have a non molested one. Thread Starter
Car: 1992 RS
I have a new motor on the stand for my 90 Camaro that might be a good fit for it, It's a large bore 305 with 6.25 rods and a JRC solid roller cam that might see 8,000 rpm. If the small ports will flow the needed amount (15% less then a 350) I am sure it will love the short runners.
Now if AFR will ship me the heads i ordered for it 4 weeks ago (was quoted 2-3 weeks) this thing will get done.
Jerry
Car: 1992 RS
I said "I don't think this is a good choice for a 350 or larger size motor"
Jerry
Jerry
Axle/Gears: 9bolt
I think there is potental if it is welded up and ported. I would make the areas wider where they transition into the plenum, and taller where the injectors sit. Jerry knows exactly how to do it.
TA
TA
Car: 1989 GTA
Engine: 369 TPI
Hey TA, speaking of intakes, how is the aluminum mining going on your intake? You should have quite a pile of aluminum.
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
While lurking around, I've heard more than a few local members talk about their theoretical 305 setups, but they usually get passed up for the bigger-numbers 350.
Nice to see someone from the socal 'skunk works' putting something together.
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
'Skunk works'?.....no, that's the concept / development home of the -BO91 HSR
Bill
Bill
Car: 1990 RS
Engine: LO3 TPI
Transmission: W/C T5
Let me clear this up for everyone…
When it comes to Jerry its straight Black Ops. Unconventional warfare, misdirection, unlimited resources, and all wrapped in plausible deniability.
A gentleman after my own heart…
I F@#KING LOVE YOU MAN!!!
Car: 1989 GTA
Engine: 369 TPI
"It's a large bore 305 with 6.25 rods and a JRC solid roller cam that might see 8,000 rpm."
Doing some math that is about the same cfm as a 350 turning 7000rpm. I better keep a sharp lookout. That motor has some serious potential.
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Jerry's version of a 305 more like the NASCAR version of a 350.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
my question is...
why a 305?
especially if you are going to do a large bore, you are practically building a 350
why a 305?
Jerry
Got the intake in today
and have started fitting the fuel rails, egr and sensors. I hope to get it on the flow bench this weekend and will post the numbers if i do.
Jerry
Jerry
Car: 1989 GTA
Engine: 369 TPI
Jerry, are you going to bring the intake to the meeting?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I can handle two looks, have you got change for a $100?
If you need specialty legth bolts go to a place called rainbow bolts in riverside. I once bought some weird size allen heads from them for slp runners I had and couldn't find these anywhere else. They are off riverside avenue.
Jerry
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Jerry
Axle/Gears: 9bolt
This manifold is an excellent starting point for his (small discplacement, high RPM) engine program. It would need a lot of work to be good on a larger engine, and would probably sacrifice torque over a longer runner design.
Considering the price of my current intake project, including buying the Vortec baseplate and super ram, about $300 now in welding, and about two hundred dollars in tools to port it, not to mention the hours of frustration, his purchase price is a smokin' deal.
Powerful is not cheap, cheap is not powerful.
TA
TA
Car: 1989 GTA
Engine: 369 TPI
Agree Troy. Most do not realize the work that goes into modifying one of these intake systems.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Either way I wouldnt of been able to spend that much money. You can test it out on my car though to make it up for me though.
